August 17, 2011, 14:17 |
Axial Compressor experts needed....
Arun raj.S
Rep Power: 16 |
Hi guys,
Actually i need to produce distortion on the inlet of axial compressor and i need to study the effects on distortion . In actual compressor test they will follow some methods like Mesh Distortion Screens , Air Jet distortion generator. Even in most journals they have talked about the Distortion screens only. But these methods will consume some very Higher grid points it seems . we have facility only to do simulation with maximum of 8 million node counts. We have tried to produce distortion with porous domain at the inlet of the compressor. It has not given much satisfactory results for us. So any one suggests some methods/techniques to produce the distortion. I have attached some images which might be useful for you to get an idea... Last edited by arunraj; August 17, 2011 at 19:27. |
August 17, 2011, 18:34 |
Rep Power: 144 |
If the loss due to the distortion mesh is not significant then ignore it. If it is significant then model it using a porous domain. Sounds like you have already tried this but not suceeded yet - keep at it, this is far better than directly modelling the mesh!
August 17, 2011, 18:58 |
Arun raj.S
Rep Power: 16 |
Hi Glenn Horrocks,
Can you explain some what detailed manner?...You are asking me to stick on this same idea...But this model doesn't capture the effects of distortion well...I have attached some of the post files(velocity and pressure variation) for the porous domain ..Go through in your free time and give me some idea...Thank you so much your kind help Glenn |
August 17, 2011, 19:03 |
#4 | |
Rep Power: 144 |
August 17, 2011, 19:16 |
Arun raj.S
Rep Power: 16 |
I need to study the effect of this inflow distortion from inlet to outlet. You check the variations in pressure and velocity . It has no specific meaning. It also not matches the experimental results. I have also attached the domain
August 17, 2011, 19:21 |
Rep Power: 144 |
Sounds like this issue is covered in the FAQ:
http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F |
how to plot out circumferentially mass averaged axial velocity in a rotor? | wildli | FLUENT | 0 | July 17, 2010 15:54 |
Transient axial rotor/stator convergence issue? | Nicola Viscanti | CFX | 3 | March 17, 2010 04:15 |
Axial Compressor CFD-Help needed | Pankaj | CFX | 1 | April 29, 2008 13:29 |
Model Axial Fan | Chien-Chi Chao | Siemens | 1 | February 1, 2001 22:13 |
About the design of axial fans | HanCheolHeui | Main CFD Forum | 0 | September 8, 1998 10:13 |
