root mean square velocity
Old   August 16, 2011, 08:25
Default root mean square velocity
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
I am simulating the flat plate with finite thickness. I am using fluent 12.1 and running URANS simulation. I am interested in the wake behaviour of different trailing edge shapes.
During this process I would like to plot the temporal rate of change of fluctuation velocity (root mean square) that is
\frac{\partial \ V_{rms}}{\partial t}
Far is offline   Reply With Quote
Old   August 16, 2011, 08:26
Far
Sijal
err : software is CFX 12.1
Old   August 17, 2011, 09:24
Matthias Voß
mvoss is on a distinguished road
switch the post to the fluent branch...?
mvoss is offline   Reply With Quote
Old   August 17, 2011, 11:15
Far
Sijal
using both codes
Old   August 17, 2011, 19:38
You can do this in CFX using the transient statistics. Look on the output tab in CFX-Pre.
Old   February 13, 2013, 09:24
Mina
Mina_Shahi is on a distinguished road
Hi Glenn
I need to plot rms value of the stream wise velocity fluctuation in my fluid domain(√(u' u' )) .
since before running the transient case i specify velocity in the transinet statistics. so in my variables i have velocity correlation uu.Trnavg.
is that sqrt(velocity correlation uu) representing (√(u' u' )) ?
Mina_Shahi is offline   Reply With Quote
Old   February 13, 2013, 09:28
Default phase averaging data in CFX
Mina
another question:
when you specify velocity or other variables in the transinet statistics. in variables you have variable.Trnavg.
which means data has been average over the whole simulated time. but if you want to do phase averaging or make data averaged over just few periods of time is that possible?
Old   February 13, 2013, 18:12
If you want only partial time averaging or phase averaging you will have to export it and do it yourself.
Old   February 14, 2013, 06:53
Mina
Thank you Glenn!
what about "velocity correlation uu" is that representing (u' u' )?
or is sqrt(velocity correlation uu. Trnavg) representing (√(u' u' ))? i want to plot the rms value of velocity fluctuation, is that the right way?
Old   February 14, 2013, 17:12
If you are using a turbulence model then you can get u'u' from the turbulence intensity or the Reynolds Stresses (if a RSM). You can also do the Trnavg functions on these variables.
Be careful with averaging of these functions. Note that sqrt(transient average(u'u')) does NOT equal transient average(sqrt(u'u')).
Old   February 17, 2013, 06:40
Mina
If you are using a turbulence model then you can get u'u' from the turbulence intensity or the Reynolds Stresses (if a RSM). You can also do the Trnavg functions on these variables..
thank you for your answer, i am a bit confused with that!
in the Transient statistics there are different options: 1/ Arithmetic Average
2/ Root Mean Square and ....
In my transient simulation i used the first option Arithmetic Average and then as a variable i selected velocity ...
now as i mentioned previously i am interested in the rms axial velocity. so i am plotting the sqrt(velocity correlation uu. Trnavg) which i am not sure if it gives me rms axial velocity or not ! that is my first question !!!
i think i had to go for the Root Mean Square in the Transient statistics option, am i right?
if the transient calculation finished is that a way to get Root Mean Square values?
which one i should look for? apparently sqrt(velocity correlation uu. Trnavg) gives sqrt(transient average(u'u'))
Old   February 17, 2013, 06:50
Read the documentation on the "velocity correlation uu" variable. It is not the axial velocity.
Old   June 1, 2016, 09:58
Default Any suggestions on how to do it?
  #13
Nazanin Ansari
ansari.nazanin is on a distinguished road
Hello, i want also plot the rms values of the velocity and i am really confused reading this thread:
-i don't find the options you named under transient simulation in Output tab by ANSYS CFX-Pre
-Is it possible to plot these fluctuations using SST model?
- I am also doing the simulations with RSM models, how is that possiblr to plot?
- I do not find the variables with Atrnave function! Could you please help me?
ansari.nazanin is offline   Reply With Quote
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 20:08
Fully developed 3d velocity profile: Square inlet! Taru FLUENT 6 September 14, 2015 09:38
help with UDF for contact angle based on contact line velocity gandesk Fluent UDF and Scheme Programming 14 October 29, 2012 14:58
how to compute relative velocity from absolute? spk Main CFD Forum 3 July 9, 2010 09:42
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
