August 13, 2011, 01:46 |
Making Wave in free surface flow
omid
Rep Power: 15 |
Hi all
I am trying to simulate a ship on free surface flow with sinusoidal wave that's made by wave maker. How can i simulate this sinusoidal wave as a boundary condition for investigate the motion of ship? Thanks Best regards. |
August 13, 2011, 08:18 |
Rep Power: 144 |
There are some posts on this forum about setting ocean wave boundary conditions. Do a search for them on the forum.
August 14, 2011, 16:50 |
Mauricio Labarca
Rep Power: 17 |
hmm well the closest i've done is a sinusoidal BC for a multiphase slug simulation... What i did is to calculate the height of the water with the sinosoidal CEL expression; then at the inlet BC i set the volume fractions of water and air to depend on an "if" cel expression; if y > (calculated height) , 1,0. that should set the air fraction to 1 if it's over your calculated height, and after yo set the water volume fraction to a similar expression you should get that sinusoidal BC.
As glenn said tho I'd check all the posts in the forum anyway to see if there's something more applied to your case. |
August 18, 2011, 04:07 |
omid
Rep Power: 15 |
Thanks mauricio.
I'd check all the posts in the forum about this, but i didn't find any useful things. Best regards |
August 18, 2011, 07:47 |
Rep Power: 144 |
Try:
en.wikipedia.org/wiki/Airy_wave_theory and folk.ntnu.no/oivarn/hercules_ntnu/.../lwt_new_2000_Part_A.pdf |
Free surface flow settubg boundary conditions and plotting velocity profiles | prashanthreddyh | FLUENT | 2 | October 21, 2015 10:58 |
Multiphase flow. Dispersed and free surface model | Luis | CFX | 8 | May 29, 2007 19:13 |
free surface flow simulation question | Jane | Main CFD Forum | 0 | April 22, 2004 14:25 |
Modeling of free surface flow | sam | FLUENT | 2 | October 29, 2003 11:39 |
SLAW, SWIFT, and XYZFS Free Surface flow | David willis | Main CFD Forum | 0 | April 10, 2000 01:22 |
