Problem with nonconstant Specific Heat Capacity
Old   August 12, 2011, 16:54
Default Problem with nonconstant Specific Heat Capacity
Diego Thomas
chameco is on a distinguished road
I am trying to use a non constant Specific Heat Capacity.
I have tried two forms, using a caloric perfec gas with a CCL routine and CFX Pre do not even generated the .def file.
Other way that I have tried is using the Zero Pressure Polinomial(using just Air Data in Material Group) but the next error happen.
+--------------------------------------------------------------------+ | Writing crash recovery file |
Details of error:-
Error detected by routine MAKDAT
CDANAM = LVAR CDTYPE = INTR ISIZE = 160
CRESLT = OLD
Current Directory : /FLOW/ALGORITHM/ZN1/SYSTEM/VARIABLES
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
| Warning! |
| The ANSYS CFX Solver has written a crash recovery file. This file |
| has been saved as |
| C:\Users\Diego\SIMULACOES\CFX\tentativa_turbomode_ 2_001\180_full.- |
| bak_020.res.err and may be an aid to diagnosing the problem or |
| restarting the run. More details should be available in the |
| solver output section of the output file. |
Someone know what is happening?
Thank's
Diego
chameco is offline   Reply With Quote
How to export the specific heat and viscosity for postprocessing (compressible) ? david39 OpenFOAM Post-Processing 2 January 4, 2019 08:04
Heat transfer problem in ansys please help me please...!!!!!!! rm2052 CFX 1 March 14, 2010 18:51
Specific heat in STAR-CD Andrew Siemens 3 September 4, 2009 00:33
Cn specific heat capacity changes with Temperatur? lightgas CFX 4 July 7, 2006 07:51
regarding B.C. of Heat transfer problem Manoj Padmakarrao Raut Siemens 0 March 17, 2005 01:01
