solve 2 "additional variable" in one simulation
Old   August 12, 2011, 15:13
Default solve 2 "additional variable" in one simulation
sajad
sajad_abasi is on a distinguished road
hi to all.
how can i solve to additional variable in one simulation?
best regards
sajad_abasi is offline   Reply With Quote
Old   August 13, 2011, 08:17
You simply add the additional variable and do the solution - but I don't think that is what you are asking. Can you clarify your question?
Old   August 13, 2011, 08:48
sajad
hi
i want to solve 2 "AV" at the same time in one simulation.is it posible?
i use ansys 13 and in default domain when i click on one of them i can change it.
i want to now if i set for eg. sa1=massflow@inlet
and then i want to define another AV "sa2" the setting for sa1 is still remain or cleaned?
thanks
Old   August 14, 2011, 07:20
You can use as many AVs as you like. Not sure what the limit is, probably in the hundreds.
But your other comments suggest you do not know what an AV is. You cannot set an AV to massflow@inlet. An additional variable is a field variable, not a single value. Single values are handled by CEL. And yes, before you ask that question, you can define lots of CEL variables also.
Old   August 14, 2011, 16:42
Default -
Mauricio Labarca
mauricio is on a distinguished road
Hello Sajad what exactly do you need from the simulation? if you just need one particular value to get as a result of your simulation for example the mass flow in the inlet you can just use the function calculator in cfx-post.
Now, if you want to solve a variable that you expect to change in every cell of your domain and you'd want to use the results for variable cutplanes and etc. then yes, i'd use an AV.
Tell us more about what do you need so we can help you out if we can.
mauricio is offline   Reply With Quote
Old   August 16, 2011, 07:06
sajad
hi.
i did it.
i wanted to have the value of two addtional variable during run to use it some where else in the run.
thanks for your replies.
Starting a 3D URANS simulation from a converged 2D URANS simulation Josh Main CFD Forum 2 June 4, 2011 21:32
Replacing mesh while running a simulation akultane CFX 1 November 15, 2009 14:46
How to solve another continuum and momentum eqn? west_wing FLUENT 0 August 25, 2003 11:00
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 11:06
Which CFD software can solve this simulation accurately? Amilcar R Arvelo Main CFD Forum 1 December 1, 1998 16:55
