August 9, 2011, 14:34 |
Heat balancing problem in coal combustion
Bharath kumar
Rep Power: 17 |
Hi to all,
Am doing a coal combustion simulation and i got converged results.but my query is, can anybody give me a procedure or idea of how heat balancing is to be done in single inlet and single outlet model using CFX post. thanks in advance |
August 9, 2011, 19:30 |
Rep Power: 144 |
A converged solution should conserve energy, so energy in equals energy out. Is that what you are asking?
August 11, 2011, 10:56 |
Bharath kumar
Rep Power: 17 |
yes ghorrocks what you said is right.
1) i have hot air and coal+air mixture in two different inlets and i get flue gas (co2,o2,N2,H2O and etc of different mass fraction) at single outlet. 2)In CFX post, i can get Temperature,Specific heat,Static enthalpy variables at various boundaries(Inlet,outlet,walls).But i can't get energy directly.So using this variables how i should do energy balance or is there any other way to do this? can you explain me. |
August 11, 2011, 20:20 |
Rep Power: 144 |
You can get energy - just integrate the enthalpy over the boundary condition and you will get energy flows.
August 12, 2011, 04:16 |
Bharath kumar
Rep Power: 17 |
thanks ghorrocks.i will try that.
August 16, 2011, 09:53 |
Bharath kumar
Rep Power: 17 |
hi ghorrocks,
i tried that what you had told. i got output unit (SI) m^4/s^2(energy flows).if i need (Watts(SI) or m^2/s^2) as output what i have to do? i need your reply. thanks in advance. |
Heat transfer problem | seojaho | CFX | 6 | May 6, 2010 01:32 |
coal combustion problem | bharath | CFX | 5 | April 27, 2009 18:17 |
regarding B.C. of Heat transfer problem | Manoj Padmakarrao Raut | Siemens | 0 | March 17, 2005 01:01 |
heat source problem | John | FLUENT | 1 | April 9, 2003 14:08 |
Coal combustion with Fluent 4.5 or 5.0! | Sriram Popuri | Main CFD Forum | 2 | July 24, 1999 12:34 |
