Timestep with mesh deformation
Old   July 19, 2011, 12:44
Default Timestep with mesh deformation
Richard Barrett
rbarrett is on a distinguished road
Hi all,
I am attempting to simulate the compression of a piston within a cylinder. The model is axisymmetric and I have used Ansys Meshing to generate the mesh. Mesh deformation is employed through the use of CEL expressions, coupled together with the use of 'Specified Displacement' mesh motion.
The problem that I am having is related to convergence 11.6 ms into a 16.6 ms compression time. Up to this point, relatively good convergence is obtained and then the solution diverges. I have tried reducing the size of the time step, but reducing this value beyond a certain point (3e-04 [s]), the model fails due to a negative volume error at multiple locations throughout the deforming zone.
I would greatly appreciate any help on this matter, particularly in relation to the size of the timestep employed.
rbarrett is offline   Reply With Quote
Old   July 19, 2011, 20:22
Highly compressing a mesh using moving mesh is difficult, you frequently get negative volume errors. You might be able to improve things using mesh weighting factors, but the biggest step forwards in this area is in CFX V14 where you have much more control over the mesh motion diffusion.
Old   July 21, 2011, 12:40
Richard Barrett
Hi ghorrocks. Thanks for your reply. Unfortunately I have only access to Ansys v12.1. Are there any other workarounds within CFX itself that may allow for more accurate modeling of a large compression, i.e. inputting a new mesh and interpolating a results file to give the initial values?
Old   July 21, 2011, 15:49
stumpy is on a distinguished road
Glenn, out of interest, what's in v14 that's new for mesh motion diffusion?
stumpy is offline   Reply With Quote
Old   July 21, 2011, 20:25
For the V14 new stuff check out the ANSYS Community portal. One thing which caught my eye in this area is the ability to define an anisotropic mesh diffusion for the mesh smoothing step. The demo case using it compared a mesh being compressed which distorted using normal isotropic diffusion, but the anisotropic diffusion kept the mesh nice as the mesh was squashed.
Richard - if you want to model a large compression and want to stay on V12 then you have two options: Either use fortran to define the mesh motion, and then you can control it directly; or put a remeshing step in there.
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 12:45
Mesh reload and deformation Attesz CFX 3 March 20, 2011 22:19
Mesh deformation using user fortran matled CFX 3 February 18, 2010 17:49
CFX mesh deformation of fine elements Ji Ke CFX 2 January 30, 2008 04:38
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
