how to use non-uniform source
Old   July 2, 2011, 08:59
Default how to use non-uniform source
ibrahim
iBra is on a distinguished road
hi guys
i have a project contain a non-uniform source
PROBLEM DESCRIPTION
there is a receiver which absorbs heat flux (W/m^2). the heat flux in the surface of the receiver is non-uniform. I have the heat flux data as X,Y,Heat_Flux.
is it possible to insert this data to ansys cfx?
i try [Hot_Point] but the problem with this function. i cant enter the value as (W/m^2)
NOTE: the non-uniform heat flux should stay static all the run_time (doesn't change with time)
I hope can anyone could help me
iBra is offline   Reply With Quote
Old   July 3, 2011, 07:57
You might be able to use a 3D interpolation function. Just define the Z coordinate to be a dummy value.
Old   July 3, 2011, 17:33
ibrahim
I am going to try it. Thank you
cfx
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
Need help with boundary conditions: open to atmosphere Wolle OpenFOAM 2 April 11, 2011 08:32
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
RasInterFoam STRANGE RESULTS AT BOUNDARY kumar2 OpenFOAM Running, Solving & CFD 8 March 24, 2008 19:38
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
