CCL Timestep Lists
Old   June 29, 2011, 07:41
Default CCL Timestep Lists
Max
max3.2 is on a distinguished road
I've got finished transient Analysis with several timesteps, and i need to run a CCL for every step to extract specified data. Here is a snippet of the problem
! $ts =350,627,903,1180,1456,1732,2009,2285,2661,2836,3111,3386,3662,3938,4213;
! for($index=1; $cnt<=(15); $cnt++){
> load timestep=$ts[$index]
##Working CCL for one timestep with using the timestep number one time for naming a file like
! open(OFH,">HoeheMassFlowAves $ts[$index].dat");
Now im getting an error at the closing bracket position of the 1st for-loop. Im not that good at CCL, nor i can find any libraries, so there are maybe some syntax-erros while using the list. Can someone help? doing this manually would take a lot of time, since playing the CCL for one step is about 15minutes and the list above isnt complete
Regards
Max
max3.2 is offline   Reply With Quote
Old   June 29, 2011, 08:32
Lance
Lance is on a distinguished road
I think you need a ! before the last }, like:
and not
Lance is offline   Reply With Quote
Old   June 29, 2011, 09:47
Max
Hi Lance,
thanks, would have searched ages for this.
Now, there isn't any error. Session gets loaded, but then nothing happens. Is there a mistake in calling the timesteps from the list? I havent found any examples for lists so i just did it like its used in other languages...
Old   June 29, 2011, 10:01
Lance
I think your for loop definition is wrong, you mix $index with $cnt. Try:
! for($index=1; $index<=(15); $index++){
Also, indices in arrays are zero-based. Example:
@array=(2,4,8,10);
$var = $array[0]; # gives $var == 2
($var1,$var2) = $array[2,3]; # gives $var1 == 8, $var2 == 10
Old   June 29, 2011, 11:13
Max
Yeah...sorry for this stupidity, heat around here seems to get in my head
Its working now, thanks for the great help
Restart 2-way FSI with different timestep? Lance CFX 10 April 17, 2013 01:37
How to interrupt unsteady calculation and carry on without timestep increase? aleisia FLUENT 1 March 19, 2011 00:02
Timestep study ijk CFX 6 April 9, 2010 08:38
interTrackFoam timestep virginie_e OpenFOAM Running, Solving & CFD 4 April 6, 2009 06:02
Use of Timestep in obtaining solution. hagupta CFX 7 February 28, 2006 14:14
