June 3, 2011, 04:12 |
Over constrained Boundary Conditions
Rep Power: 18 |
Can some one please tell me if it is a over constrained approach to specify both volumetric flow rate and pressure on a inlet boundary
Best regards, Santhosh. |
June 3, 2011, 06:13 |
Redddy
Rep Power: 16 |
yes, absolutely it is over constrained approach. moreover, its not possible to given two boundary conditions at one side.
May i know where you want to use? |
June 3, 2011, 08:57 |
Rep Power: 18 |
Can you please tell me how to calculate pressure over the inlet given the volume flow rate and the fluid used being Air
June 3, 2011, 12:15 |
Redddy
Rep Power: 16 |
you can calculate velocity for given flow rate. then calculate total pressure over surface by using static pressure plus dynamic pressure.
Still, u had not in circle, describe your problem in detail.. |
Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 25 | February 27, 2016 13:58 |
symmetry boundary conditions in cfx | lost.identity | CFX | 41 | May 22, 2013 08:21 |
OpenFOAM Variable Velocity Boundary Conditions | NickolasPl | OpenFOAM Programming & Development | 2 | May 19, 2011 06:37 |
[Netgen] boundary conditions and mesh exporting | vaina74 | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2010 10:38 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
