signal 11, segmentation violation, DISPLAY variable
Old   June 2, 2011, 14:00
Default signal 11, segmentation violation, DISPLAY variable
Sara S.
sakalido is on a distinguished road
Hi all,
I am running CFX-post in batch mode, What I do is I use ssh in a windows machine to a linux cluster and basically I am trying to run cfx-post in batch mode in this linux cluster remotely.
I get this error message: "signal 11 was caught: segmentation violation".
previously I solved this problem in my Windows laptop by using the following command:
export DISPLAY=$(name of linux machine):0.0
but now even using this command I have the same problem. I searched in the forum but I couldn't find anything helpful.
Does anybody know what is the problem and how can I solve it?
thank you
sara
sakalido is offline   Reply With Quote
Old   December 20, 2013, 18:03
ali
alinik is on a distinguished road
Were u abloe to resolve this issue? I am getting the same error message in solution stage.
Any kind of information that might help is greatly appreciated
Thanks
alinik is offline   Reply With Quote
batch mode, cfx-post, display variable, segmentation violation, signal 11
How to remove the error:FLUENT received a fatal signal (SEGMENTATION VIOLATION). Conan FLUENT 9 December 20, 2019 13:31
emag beta feature: charge density charlotte CFX 4 March 22, 2011 10:14
A fatal signal (segmentation violation) sutthinan Fluent UDF and Scheme Programming 6 March 16, 2011 19:35
signal 11 was caught: segmentation violation Ahlo CFX 1 August 3, 2009 12:05
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
