Transient heat flow
Old   June 1, 2011, 12:49
Default Transient heat flow
saisanthoshm88 is on a distinguished road
I'm totally new to transient simulations. I had a newbie question. I was simulating the air flow inside a power amplifier cabinet which had Fans, Power sources and power amplifiers inside.
The power emanation from the amplifiers is of a transient nature and is described by the following details:
Output Power = 200 W
Duty cycle: Transient attribute:Gaussian, Total pulse duration: 6400 ms
So I see that I need to consider 6400 ms as the total time with a time step of 400 ms. But this is something relevant to a single duty cycle so will it be fine to analyze the heat flow inside the cabinet just for a single duty cycle on these lines.
Can some one please suggest me regarding this.
Best regards,
Santhosh.
saisanthoshm88 is offline   Reply With Quote
Old   June 1, 2011, 19:29
In most electronics heat modelling things of this time scale can be averaged out and the avergae heat load used. So I would average the heat load out and apply a constant heat load. But if you are doing a transient simulation anyway then it is easy to apply the transient heat load.
Old   June 7, 2011, 13:02
Glenn could you please tell me how to calculate this average heat load. I apologize for raising such novice question but my experience is really too limited in this.
Best regards,
Santhosh.
Old   June 7, 2011, 20:00
Integrate the heat load over a long time. If it is 11W for 1s and then 1W for 4s, and then repeats that pattern forever, then integrating over the full 5s cycle gives (11*1+1*4)/5 = 3W average load.
transient result in spray reactor with swirl flow glenn creten Main CFD Forum 1 August 14, 2012 06:10
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Heat Transfer boundary conditions for engine coolant flow simulation rajuks Main CFD Forum 0 February 15, 2010 10:04
Flow around pipes - heat transfer coefficient on the wall of pipe doodek Main CFD Forum 2 November 23, 2009 09:48
time averaged heat transfer in oscillating flow Matthieu Ubas Main CFD Forum 2 November 5, 1999 15:20
