Simulation of Axial Fan Flow using A Momentum Source Subdomain |
#21 |
Rep Power: 13 ![]() |
Hello philflow,
have you written an FAQ or a short summary of your experience with an axial fan simulation? I'm working on the same problem. It would be very nice if you have something like an summary for me! Best regards, A. |
#22 |
Rep Power: 144 ![]() ![]() ![]() ![]() |
The documentation describes source terms and source term coefficients pretty well.
#23 |
Hello again,
I have problems to simulate an axial fan. In the image, the test case I am working with is shown. The green bar, is my subdomain. ![]() I am able to set a momentum source to get the exact pressure rise. But this is only half the way I have to go. I would like to set a specific pressure rise and a volumeflow rate. My idea is to simulate different blades in my fan. the first blade has an pressure rise of 35[kPa] and a volume rate of 70 [m^3/s] the second one has a pressure rise of 35 [kPa] and a volumeflow rate of 50[m^3/s]. So in my opinion the subdomain is a "black box" for my blades. And I am able to simulate different blades. I have tried a lot of possibilities. 1.I rotate the subdomain with the frame change model "stage" and give a axial momentum source 2.I try to give an axial and a theta momentum source 3. I give an axial momentum source and an energy sourc I have no more real ideas how to simulate different blades in my nacelle. I hope someone can help me. Thanks a lot. |
#24 |
here is the image
http://www.flickr.com/photos/95041584@N02/8660319970/ |
#25 |
I think you will find that specifying the pressure rise and flow rate is over-specifying the flow. You specify either the pressure rise or the flow rate but not both. You can even specify the pressure rise as a function of flow rate (or vice-versa) - in fact the is recommended if you are trying to find the operating point and you do not know the exact fan speed.
#26 |
Is there no way to specify both parameters? In my thougths it is like I have two different Operating Points which I can define. Or like two different blades.
Blade 1: pressure difference 35 [kPa] with 70 [m^3 s^-1] Blade 2: pressure difference 35 [kPa] with 60 [m^3 s^-1] With only the Momentum Source I can give a pressure change and a result is a volumeflow rate. The task of my simulation is to find solutions for my nacelle with different blades. |
#27 |
Edmund Singer P.E.
Rep Power: 21 ![]() |
Glenn is correct. You are overspecifying the problem. I assume your blades have more than one operating point. You should have a mdot vs Pdrop for each blade.
You can input this into your model, and your model will find the operating point using the Pdrop of your system. |
#28 |
Hanumanth
Rep Power: 17 ![]() |
In fluent there is only possibility of defining momentum source in either x,y & z directions. If we want to define momentum source over a cylinder, then how to do this in fluent. Hey guys please help me regarding this, as this option is not there in fluent.
Thanks in Advance... |
#29 |
Edmund Singer P.E.
This is a CFX forum. Try Fluent Forum.
But with not much thought put into the answer, you could use a coordinate transform to put your source into cartesian coords. |
axial, fan, momentum source, subdomains |
Axial fan simulation in UG/NX 7.5 | fan123 | Main CFD Forum | 2 | April 23, 2011 08:22 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
flow simulation across a small fan | jane luo | Main CFD Forum | 15 | April 12, 2004 17:49 |
Modeling a fan with a momentum source | Pascale Fonteijn | CFX | 2 | November 21, 2002 16:33 |
Question concerning about the flow simulation of a fan in an engine room. | ghlee | Main CFD Forum | 3 | October 21, 1998 07:05 |
