May 25, 2011, 03:07 |
An error has occurred in cfx5solve
D.Pandarinath
Sir,
i am new to the ANSYS, I am using ANSYS 13.0 i had done with geometry,meshing using work bench i had given all the requied data like Domine, boundary, interphase in Fluid flow(CFX)-CFX-Pre. when i am using solution option in work bench (Fluid Flow(CFX)-CFX-Slover manager). i am getting the Error as follows. An error has occurred in cfx5solve: The ANSYS CFX solver has terminated without writing a results file. Command on host pandupc (PANDU-PC) exited with return code0. Also some warnings like ********* WARNING ********* | | No control surfaces have been found for the domain interface | | Interface | | | | If you expect this to occur, please set the expert parameter | | 'ggi permit no intersection=t' to work around this message. | | | | Possible setup errors leading to this situation are: | | 1. An incorrect axis of rotation for a rotating domain or domain | | interface. | | 2. A frame change model is used in which there is unequal pitch | | shapes, or circumferential orientation, but the Pitch Change | | model is set to None. | | 3. The transient rotor stator model is used when the geometry | | does not span 360 degrees and the Pitch Change model is set to | | None. please any one give me the solution. |
May 25, 2011, 07:34 |
Rep Power: 144 |
Looks like an interface is not set up correctly. Either one side of the interface has no surfaces or the two sides of the interface do not intersect.
August 21, 2012, 00:28 |
#3 | |
Gabriel Cabrera
No control surfaces have been found for the domain interface | | Interface | | | | If you expect this to occur, please set the expert parameter | | 'ggi permit no intersection=t' to work around this message. | | | | Possible setup errors leading to this situation are: | | 1. An incorrect axis of rotation for a rotating domain or domain | | interface. | | 2. A frame change model is used in which there is unequal pitch | | shapes, or circumferential orientation, but the Pitch Change | | model is set to None. | | 3. The transient rotor stator model is used when the geometry | | does not span 360 degrees and the Pitch Change model is set to | | None. I checked the domains of the interface, and they are connected. I would like to know what other things I can check, and if it´s possible to give me your email so that I can send you my simulation. Or, I could share the document with you via dropbox. Either way would be perfect. Thank you for your supportting. |
August 21, 2012, 20:35 |
Rep Power: 144 |
Please do not PM spam me with duplicates of stuff you have already posted on the forum. It is very annoying.
The error message is quite clear - your GGI is not matching up. I do not have time to find it for you, you need to have a closer look at your setup to find it. |
August 21, 2012, 21:24 |
Gabriel Cabrera
Thank you for your quick reply. Best Regards
Error #001100279 | bharath | CFX | 9 | March 25, 2015 06:31 |
Error in CFX Solver | Leuchte | CFX | 5 | November 6, 2010 07:12 |
An error has occurred in cfx5solve: | yuan | CFX | 1 | June 8, 2008 16:12 |
An error has occurred when Writing backup file | tian | CFX | 0 | June 28, 2007 22:29 |
ERROR #001100279 has occurred in subroutine ErrAct | Carl | CFX | 2 | July 16, 2005 15:39 |
