May 15, 2011, 04:10 |
setup K,E parameters in CFX 13
anonymous
Rep Power: 15 |
HE ALL ;
I want to pass parameters for sigma k and e in k-Epsilon Model with CEl Function ; it seem that it's not permit in CFX 13. wich accept only constants . is there any file or env varaiable to edit and change to make CFX 13 accpet CEL function . thanks |
May 15, 2011, 18:59 |
Rep Power: 144 |
You may be able to do this by editting the <CFX_ROOT>/etc/VARIABLES file. But no guarantees, and remember that the reason you cannot define it as a variable is because it is not properly implemented in the solver and all the cross terms which arise from this are not accounted for. In other words - "At your own risk!"
May 18, 2011, 04:55 |
anonymous
Rep Power: 15 |
it's not possible to pass with Cel function , also changing to version 12.1 same result , for this closure parameter CFX accept only constant perhaps it's a limitation of CFX ?
May 18, 2011, 06:06 |
#4 | |
Rep Power: 144 |
Why do you want them to vary anyway? It means you will not be using the k-e turbulence model. What is different about your model to require it? |
May 19, 2011, 11:21 |
anonymous
Rep Power: 15 |
Hi ghorrocks;
I use K-Eps model , but i wan't to pass values for sigma_E ( dissipation) with CEL function as follow: sigma_E = if( z< seuil, 0.5, 1.3) that means the value is 0.5 or 1.3. |
May 19, 2011, 18:49 |
Rep Power: 144 |
Why do you want to do this?
May 20, 2011, 14:55 |
anonymous
Rep Power: 15 |
to check the possibility of enhancement of concentration prediction
May 21, 2011, 07:54 |
Rep Power: 144 |
I see.
Have you tried editting the VARIABLES file as suggested? |
May 21, 2011, 18:01 |
#9 |
anonymous
Rep Power: 15 |
Yes I edited the VARIABLES file but there is no ligne pointing to this parameters to change it.
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Guide setup PVM CFX | painterwolf | CFX | 12 | May 24, 2009 19:47 |
Electronics Enclosure Analysis with CFX | Simulation Engineer | CFX | 1 | April 22, 2009 11:08 |
CFX 10's solutions differ from CFX 5.7's | Atit Koonsrisuk | CFX | 4 | July 26, 2006 11:59 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
