CFX v12 adding reattachment modification to sst model |
June 8, 2016, 15:30 |
#21 |
ali
Rep Power: 17 |
Folks,
I compared v17.1 and v15.0 that I am using and saw that this option is available in the newer version. both versions are using the same license file and thus I do not think it is a license issue. Also in both versions beta features are enabled. Judging by the date that this conversation has started I assume there has to be a way to get around this problem in earlier versions. I hope those people that have solved this issue in earlier versions respond and let me know how they overcame this issue. I really do not want to upgrade to v17.1 for some reasons and would like to find a solution in my own v15.0 Thanks, Ali |
June 9, 2016, 06:30 |
#22 |
Rep Power: 144 |
If Far is correct and Menter does not think the model is physically correct then ANSYS may well have removed it entirely from the software.
June 9, 2016, 12:17 |
#23 |
ali
Rep Power: 17 |
It is there in GUI in v17 but not in v15. I read in some other thread that this option is only available using command editor in earlier versions. The question is why I am getting that error when I try to activate it through command editor in v15.
Also if you look at the transport equation for intermittency in SST model you will see that it is not based on physics and it is something that ansys has been saying for long. It is just designed in such a way to produce acceptable results for a wide range of inputs. As long as it is working just fine then there is no problem in using it. The question is how I can activate it? Also if anyone has any documentation in this regard I would really appreciate it if they can share it with me. I dug in ansys documentation and theory guides but I could not find any good solid material. Thanks, Ali |
June 17, 2016, 05:33 |
#24 |
he is nice guy and usually reply
This paper discuss same model in detail, and they also quote their discussion with menter. http://turbomachinery.asmedigitalcol...icleID=1468333 Last edited by Far; June 17, 2016 at 09:42. |
June 20, 2016, 03:56 |
#25 | |
Rep Power: 10 |
TURBULENCE MODEL: Option = SST REATTACHMENT MODIFICATION: Option = Reattachment Production END END |
August 31, 2016, 04:11 |
#26 | |
Tomas
Rep Power: 11 |
in my case the solution was well.... stupid Try to switch off and again switch on beta features. This helped me. I spent a lot of time finding out where the problem is like you. Jepice |
Low Reynolds Number SST Model | Josh | CFX | 41 | June 4, 2023 19:00 |
[ICEM] Proper way to name boundaries on 2D model for use in CFX? | RossFS | ANSYS Meshing & Geometry | 4 | November 10, 2011 02:38 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 13:57 |
Turbulence model for CFX moving mesh | songxguan | CFX | 7 | June 28, 2009 21:05 |
Help: 2D model in CFX 5.5 | Dejun Jing | CFX | 1 | July 24, 2002 00:25 |
