Comparison of fluent and CFX for turbomachinery
Like Tree6Likes
Old   May 27, 2011, 09:52
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Originally Posted by ghorrocks View Post
Well, the segregated solver does not introduce errors - it just has a looser coupling between the momentum and pressure/mass equation and therefore if the coupling is tricky it makes convergence more difficult. A properly converged segregated solver will be as accurate as a equivalently converged coupled solver.
Segregated solvers iterate much faster, so for cases where the tight coupling is not so important they are superior. For instance you will find segregated solvers often out-perform coupled solvers in transient simulations.
yes you are right
Far is offline   Reply With Quote
Old   August 29, 2011, 10:28
Diego Thomas
chameco is on a distinguished road
Hello Far,
How you simulated in CFX using the S-A turbulence model? As I know S-A is not implemented in the CFX Solver
chameco is offline   Reply With Quote
Old   September 5, 2011, 08:26
Far
Sijal
ya I did. It is implemented as the Beta Feature, and can be activated in CFX Pre
Old   September 7, 2011, 16:08
Far
Sijal
any success in using SA model ?
Old   September 7, 2011, 16:50
Diego Thomas
No. Do you refer in CFX pre Beta version is implemented?
I read all the CFX manuals and did not find anything about S-A model. Just one model of one equation developed by Menter.
Thank's
Old   September 8, 2011, 07:24
Far
Sijal
Check out this pdf file and you find that SA model is implemented in CFX (from CFX 11 and still as beta in V 13)
http://www1.ansys.com/customer/userg...2.0-update.pdf
Old   September 8, 2011, 07:43
Far
Sijal
http://www.ansys.com/staticassets/AN...tech-specs.pdf
it surely contains the reference that CFX has SA model as beta feature. It should be noted that there are no details given in CFX help regarding beta features.
Old   September 14, 2011, 16:24
Diego Thomas
Nice. I will try to find the beta feature.
Thank's a lot.
Old   September 14, 2011, 17:28
Far
Sijal
it is very much simple. Attached files describe how to activate the beta features
Old   April 3, 2012, 22:08
mahdi abdollahzadeh
mm.abdollahzadeh is on a distinguished road
Hi Far
I am trying to model NASA Rotor 67 with fluent . but I have alot of problem. I can obtain the correct pressuare ratio for near pick efficny but in other cases i am not able.
Could please give me more information about you fluent case setup of NASA Rotor 37 ? in fact i dont have the grid coordinates and the experimental datas for Nasa Rotor 37to start modelling that.
I will be too much thankful to recive your help and suggestions
Best
Mehdi
mm.abdollahzadeh is offline   Reply With Quote
Old   December 22, 2014, 06:21
mohamed mohsen
sehs15 is on a distinguished road
which type of boundary conditions did you use in FLUENT? did you use turbo specific non-reflecting BC ?
sehs15 is offline   Reply With Quote
Old   December 25, 2014, 14:54
Far
Sijal
These were standard boundary conditions
Old   December 26, 2014, 19:11
JuPa's Avatar
Mr CFD
JuPa is on a distinguished road
This is actually a fantastic and informative thread.
JuPa is offline   Reply With Quote
Comparison: COMSOL, Fluent, CFX glennfulford Main CFD Forum 2 November 22, 2009 03:05
Fluent Vs CFX, density and pressure Omer CFX 9 June 28, 2007 05:13
Comparison among CFX, STARCD, FLUENT, etc ? Jihwan Main CFD Forum 13 October 12, 2004 13:02
comparison Of CFX with FLUENT rou CFX 3 April 26, 2003 02:10
comparison Of CFX with FLUENT rou FLUENT 1 April 1, 2003 20:18
