Passing Values in Multiple points by 1 CEL Function |
May 5, 2011, 17:06 |
Araz
Rep Power: 15 |
Does anyone know haw we can pass multiple values from CFX to a compiled subroutine using one function? In CFX documentation I can only find cFX expressions which pass only a single value to a subroutine. For example, consider that we need to pass the values of static pressure, Temperature and X,Y,Z coordinates of all nodes located on a boundary to the subroutine (named TEST) using 1 function. Is it right to define the arguments in the subroutine as following? P=ARGS(1:NLOC,1) T=ARGS(1:NLOC,2) X=ARGS(1:NLOC,3) Y=ARGS(1:NLOC,4) Z=ARGS(1:NLOC,5) NCLOOP = INT(ARGS(1:NLOC,6)+0.1) Output= RET(1:NLOC,1) Do these statements include the corresponding variable at all nodes? if yes, Then I will create a User CEL Function in cfx and also write this function as an expression in our ccl file: TEST= Blade Function (P,T,X,Y,Z,aitern) and now I need to define these arguments in cfx (this part is the main problem) : can I write something like this: P=Pressure@Blade T=Temperature@Blade X=XGlobal@Blade Y=YGlobal@Blade Z=ZGlobal@blade ??? and since my output is displacement of nodes in Y direction, then I can write: Ydisp= TEST, and when it comes to specify my boundary conditions for the blade I will put this expression in the place where I specify the mesh motion in Y direction. if this procedure is not correct, please provide me with some guidance. Thank you, Araz Last edited by Araz; May 5, 2011 at 19:54. |
CEL function in CFX | ehsanshams | CFX | 3 | October 14, 2010 22:27 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 01:35 |
help on mass sink using CEL function | buhkuh | CFX | 0 | March 19, 2008 00:57 |
ICEM clustering of mesh points and multiple edges | webhaw | CFX | 4 | July 25, 2007 17:29 |
CEL insertion of points into domain? | Adrijana | CFX | 1 | December 7, 2006 08:48 |
