April 25, 2011, 09:00 |
turbulence model?
jaikrishna
Rep Power: 17 |
hi,
i'm simulating centrifugal compressor, which's rotating at 100,000rpm. which turbulence model is better for this? can i use k-E model (with y+ is 10-20) for this? some people recommended to use sst but for sst-model is y+ < 2. it difficult to maintain this y+ on all region. please help me to understand and choose. thanks. |
April 25, 2011, 09:51 |
you should not use K-E model, since you will have a complex fluid flow distribution, if you read more about K-E model you will find that this model does not suit for this application since you will have rotation and swirl. I suggest you to use RSM
April 26, 2011, 22:59 |
#3 | |
Rep Power: 144 |
The best default option is the SST model. Only change away from this model when you have a good reason to do so. SST works fine with y+ in the wall function region (ie >11), so SST does not demand a y+<2 mesh. |
April 27, 2011, 09:53 |
I agree with you about the two model equation, they are the most efficient when the computational resource is low. However we have to take into consideration several condition when they are used.
One of the most important is when there is swirl, like is this case, due to the fact that is a turbumachine, you have to make some proves with the turbulence models, starting with the two equation until RMS. No doubt RMS is the most complex and you need a lot of computational resource, this is the worst part. FLUENT has several information about it, and from my point of view they explain in more details the topics. Yours sincerely JM |
April 27, 2011, 10:35 |
Rep Power: 21 |
If swirl is important then use SST and enable the Curvature Correction option. This should give something closer to a RSM solution in swirl regions, but retaining the benefits of the wall treatment with the SST model.
April 27, 2011, 20:29 |
Rep Power: 144 |
In my experience for many flows RSM does not give results any more accurate than a two equation model, even though many two equation models do not include curvature effects.
That is why I recommend SST as a starting point, and enable curvature correction as Stumpy suggests. I would be surprised if an RSM model proves to be more accurate than this, even though RSM models contain "more physics". |
April 28, 2011, 00:50 |
RE:
jaikrishna
Rep Power: 17 |
As you have suggested, tried RSM model and the convergence is poor.
So decided to go about with the SST with curvature correction option. Thanks for you suggestions. |
Wrong calculation of nut in the kOmegaSST turbulence model | FelixL | OpenFOAM Bugs | 27 | March 27, 2012 10:02 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 14:57 |
KOmega Turbulence model from wwwopenFOAMWikinet | philippose | OpenFOAM Running, Solving & CFD | 30 | August 4, 2010 11:26 |
Fan heater model: what turbulence source to use? | andy20 | CFX | 7 | March 3, 2008 17:42 |
SSG Reynolds Turbulence Model | Georges | CFX | 1 | February 28, 2007 17:15 |
