February 10, 2012, 08:01 |
#21 |
Lauren Dransfield
Rep Power: 14 |
I think so, but it might be in the -x direction
February 10, 2012, 16:24 |
#22 |
Marko Milasinovic
Rep Power: 15 |
No, it isn`t in X direction. I have velocities in 3 direction, see post 9
February 10, 2012, 16:31 |
#23 |
Lauren Dransfield
Rep Power: 14 |
I don't understand what you mean?
I have my plane on the y-z axis and the flow normal to that, hence my spacial fields are all plotted x-y. I am however, quite new to this, and none of my peers are at such a high level as these are individual projects so I know nobody near here to help me as we are all using different software. If you believe I have made an error would you mind helping? I am trying to plot the flow for this. Which is the LAD coronary artery. |
February 18, 2012, 04:39 |
#24 |
Lauren Dransfield
Rep Power: 14 |
I'm not sure the pulsatile aspect of this is working for me, it seems not to change velocity with any function of time...any help?
July 9, 2012, 07:44 |
#25 |
Marko Milasinovic
Rep Power: 15 |
Can you tell me how to insert the same boundary profile in FLUENT? I read UDF manual for fluent but I didn`t understand. Also, I read post, but I still don`t know.
July 31, 2012, 21:01 |
#26 |
Hi friends !
I'm a beginner, Maybe my question is a little bit off the topic. I wonder how can i find a proper geometry for the Aortic Arch? I have found out that to design the geometry I might use multiple CAT images of aortic arch, so I can combine them in order to make the whole vessel. Any helps would be appreciated ~ Regards Mojtaba |
August 1, 2012, 06:17 |
#27 |
Marko Milasinovic
Rep Power: 15 |
I designed my geometry using software Materialise Mimics.
Regards! |
Pulsatile blood flow | John H | FLUENT | 7 | March 3, 2022 07:50 |
Modeling blood flow - FloWorks | mcneelyd | FloEFD, FloWorks & FloTHERM | 2 | June 15, 2009 12:53 |
FLUENT BLOOD FLOW RATE | Christoforos | FLUENT | 0 | September 18, 2008 10:08 |
3D pulsatile blood flow UDF | Michal | Main CFD Forum | 0 | February 25, 2005 07:18 |
Fluent blood flow BC | Michal | Main CFD Forum | 3 | February 17, 2005 03:17 |
