tank sloshing - getting wrong pressure
Old   April 20, 2011, 03:17
Default tank sloshing - getting wrong pressure
Hamed
enghamed is on a distinguished road
I am running a two phase tank sloshing with mesh displacement.
My tank is 10m diameter, 7 meter height with water level of 6 meter. I have made a displacement of x=asinwt.
when I run it in the solver it says:"
| Reference Pressure Information |
Domain Group: Default Domain
Pressure has not been set at any boundary conditions.
The pressure will be set to 0.00000E+00 at the following location:
Domain : Default Domain
Node : 1 (equation 1)
Coordinates : (-3.53553E+00, 0.00000E+00,-3.53553E+00).
| ****** Notice ****** |
| This is a multiphase simulation in a closed system. |
| A global correction will be applied to the volume fractions to |
| accelerate mass conservation. |
Buoyancy has been activated. The absolute pressure will include
hydrostatic pressure contribution, using the following reference
coordinates: (-3.53553E+00, 0.00000E+00,-3.53553E+00)."
The coordinates which the solver mentions for the reference pressure is at the bottom of the tank. ( I don't know where I can specify the reference pressure in cfx-pre!)
I run it and after viewing the results I get a wrong pressure contour for pressure as you can see in the attached file. I need the correct value of pressure to calculate the force on the walls.
Can anyone help me out please?
I have attached the ccl file as well.
Regards
enghamed is offline   Reply With Quote
Old   April 22, 2011, 07:00
Hamed
Can't anyone help me on this issue? I really need help. Please advise me. I would really appreciate it. Thanks
Old   April 26, 2011, 23:09
For an incompressible solver you need to set pressure somewhere. The pressure just offsets the pressure values and does not contribute to the solution at all. So the warning message is just saying pressure is being set at the location it specifies. If this location is not good then set another.
You can set the reference pressure on the domains tab.
VOF or not for sloshing of a full tank? Brian FLUENT 3 August 17, 2011 07:35
sloshing in tank manoj kumar FLUENT 7 July 30, 2011 06:53
Pressure Rise Error emueller CFX 0 May 5, 2009 12:08
Pressure Inlet yields wrong velocities Ben FLUENT 0 November 21, 2004 02:47
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
