April 14, 2011, 15:22 |
CFX Mesh interfaces
Rep Power: 18 |
Can some one please explain why a GGI interface is preferred for Fluid-solid and solid-solid connections in CFX rather than the one-to-one interface
Best regards, Santhosh. Last edited by saisanthoshm88; April 15, 2011 at 04:28. |
April 15, 2011, 08:04 |
Rep Power: 144 |
Because a GGI uses full 2-way coupling between the domains but a 1to1 only uses 1-way coupling. A GGI will probably converge faster. Not sure but they may have fixed this in V13.
April 21, 2011, 18:30 |
Rep Power: 18 |
Glenn I think the coupling concept is applicable only in a Fluid structure interaction (FSI) but is it indeed needed at any flluid - solid (or) solid - solid interface. May be a newbie question but please clarify upon this.
Best regards, Santhosh. |
April 26, 2011, 23:12 |
Rep Power: 144 |
The coupling I am refering to here is the coupling of the heat equation in the fluid domain with the heat equation in the solid domain. These two temperature fields are coupled through the interface. Hence my answer is talking about the tightness of the coupling.
April 28, 2011, 10:11 |
Rep Power: 18 |
Oh k I was just getting confused with the FSI thing when you mentioned of coupling.
April 28, 2011, 19:46 |
Rep Power: 144 |
Coupling is just a generic term for joining one set of equations to another set. The is coupling between the pressure and momentum equations, there is coupling between a heat transfer solid and an adjacent fluid domain, and there is coupling between displacements in a FSI run. These are all different examples of how two different equation sets are coupled together.
April 28, 2011, 22:09 |
Rep Power: 18 |
Thanks Glenn. This clears up my ambiguity.
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
CFX Mesh Deformation problem | Silmaril | CFX | 7 | October 19, 2010 11:00 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
Mesh from ICEM CFD to CFX ! Error ! Why ? Thanks ! | Vu Trinh Tuan | CFX | 11 | March 28, 2005 20:04 |
importing mesh from ICEM CFD into CFX 5 | Jay | CFX | 2 | November 12, 2002 14:46 |
