July 11, 2013, 13:07 |
#21 |
sina
Rep Power: 13 |
Hi Glenn
I read in one of your previous post that running a serious Steady State simulation to find a rotational speed of rotor is the easiest approach. I wanna know if I run a series of steady state simulation with different rotor rpm, how I can get conclusion about the real rpm of rotor from the graph rpm vs torque? |
July 13, 2013, 07:59 |
#22 |
Rep Power: 144 |
It is a simple thing then to integrate through time the rpm versus torque curve to model the rotor speed versus time. The maths to do this is straight forward and should be easily done in Excel, matlab, python or whatever you like to do basic numerical work in.
July 17, 2013, 20:48 |
#23 |
sina
Rep Power: 13 |
Glenn,
thank you for your reply. you said somewhere that extrapolating to find a net zero torque in torque vs rpm curve will give us the actual rotating speed. would you please let me know the concept behind this? |
July 18, 2013, 09:58 |
#24 |
Rep Power: 144 |
Basic mechanics - if the rotor has zero torque then it runs at constant speed. So find the point where the fluid power equals the absorbed power and you have your steady state operating point.
July 19, 2013, 21:58 |
#25 |
sina
Rep Power: 13 |
Glenn,
Thank you for your help. I performed a simulation of axial turbine from start up based on Rigid body approach and I got almost the same result compared your suggestion (series of steady state simulation). I got almost the same rotational speed of rotor in both approach. In both case the torque got zero when the rotor get a steady rotation, I was wounder how I can calculate a power output based on the equation P=TW, now? Because torque=0. |
July 20, 2013, 07:06 |
#26 |
Rep Power: 144 |
If the rotor is just freewheeling around then there is no output power. But if the power/torque is being absorbed in the generator (or whatever is absorbing the power) then you just get the power straight from that.
February 24, 2016, 04:50 |
#27 |
Stuart
Rep Power: 26 |
Glenn,
How would you apply the steady-state approach if the rotating blades are obscured over some regions of the rotation, e.g. the attached image of a simple example (I've removed a lot of the geometry for clarity)? Here steady-state simulations would be needed at different angles. I too want to simulate the blades spinning up from rest due to the freestream velocity. Thanks Last edited by siw; February 24, 2016 at 05:58. |
February 24, 2016, 06:07 |
#28 |
Rep Power: 144 |
Nothing is attached. But no matter, I think I understand your question.
If you want to use the frozen rotor approach but have a configuration where there will be torque variations depending on rotor angle, then you need to do enough frozen rotor simulations at enough angles so you know the torque versus angle curve well enough that you can determine an average power. |
February 24, 2016, 07:46 |
#29 |
Stuart
Rep Power: 26 |
Glenn,
Updated the post with the image. |
March 17, 2016, 07:56 |
#30 | |
Héctor Lodoso
Rep Power: 11 |
What do you exactly mean with the quoted sentence? I do not understand the concept "steady state runs" when you talk at the same time of "rotation speed" of the rotor. Is the rotor actually moving (rotating) in a transient simulation? Or do you mean to compute the rotation speed throug the inlet wind velocity? .... |
March 17, 2016, 21:28 |
#31 |
Rep Power: 144 |
By steady state runs I mean use frozen rotor or one of those simplified rotating frames of reference models which accounts for the frame rotation inside a steady state simulation.
March 18, 2016, 04:14 |
#32 | |
Héctor Lodoso
Rep Power: 11 |
Then I understand it is a sweep of pure steady state simulations or with the use moving reference frames. But then, how could I take into account the rotation speed of the rotor in a pure steady state run? Please excuse my ignorance. |
March 18, 2016, 20:34 |
#33 |
Rep Power: 144 |
If the simulation is purely steady state with no rotating frames of reference then you can't account for the rotation. It is the rotating frame of reference model which accounts for the rotation.
please help in simulating a wind turbine blade in 6 DOF ????.... | usman naseer | Main CFD Forum | 2 | March 10, 2016 03:53 |
Ducted wind turbine (BC for the shroud) | Pepita | CFX | 4 | June 29, 2013 08:09 |
3D wind turbine modelling/boundary condition defn in rotation | bakay | FLUENT | 9 | September 14, 2011 06:32 |
Wind turbine simulation | Saturn | FLUENT | 1 | June 16, 2006 03:12 |
Wind turbine simulation | Saturn | Main CFD Forum | 1 | June 12, 2006 04:57 |
