Static pressure problem
Old   April 12, 2011, 14:11
Default Static pressure problem
Kooky
Kiat110616 is on a distinguished road
Dear All,
I was applying the boundary condition, the mass flow rate at the inlet surface and static pressure is zero at the outlet surface. So, I was checking the static pressure at the outlet surface in CFX post, it did not the same value. Anybody knows how to obtain the same value.
Total pressure is sum of static and dynamic pressure. I measured the total pressure and dynamic pressure at the outlet surface. Is that correct for predicting the static pressure?
Thank you for your respond
Kiat110616 is offline   Reply With Quote
Pressure averaging at the outlets. KM CFX 6 April 1, 2021 07:28
fprint problem MASOUD Fluent UDF and Scheme Programming 5 October 30, 2011 17:08
UDF to define or adjust pressure??? engahmed FLUENT 0 July 6, 2010 18:19
problem with static pressure Nina FLUENT 3 February 28, 2008 14:08
Static vs Total Pressure Alfonso Ferrandez FLUENT 2 May 23, 2000 09:53
