Flow regime identification
Old   April 10, 2011, 15:28
Default Flow regime identification
Dmitry Volkind
dvolkind is on a distinguished road
Greetings to everyone!
Can anyone please explain me how to identify the flow regime?
For example, if I have the flow properly resolved (or precise experimental data is available), so that all characteristics of the flow are known everywhere at every timestep, how do I determine whether the flow is laminar, turbulent or transitional?
Thanks in advance,
Dmitry
dvolkind is offline   Reply With Quote
Old   April 10, 2011, 23:23
If turbulent it will have a turbulence spectrum covering a wide range of time and spacial scales. A laminar flow will have only a limited range of time and space scales.
ghorrocks is online now   Reply With Quote
Old   April 11, 2011, 10:06
Dmitry Volkind
Thank You, Glenn! Could you please explain what is considered wide or limited range?
Old   April 11, 2011, 19:35
Go to your library and look at any textbook on turbulence modelling or turbulence theory. This is all basic turbulence modelling theory and should be explained in detail by any decent textbook. The text I use is "Turbulence modelling for CFD" by Wilcox, but there are many others.
Old   April 12, 2011, 04:09
Dmitry Volkind
Thanks again! I'll try to find some books. It has become really difficult, because foreign technical books are no longer published since USSR(
Old   April 12, 2011, 08:32
Then you should be able to find a USSR turbulence textbook. There are lots of textbooks on the topic so I bet you can find a Russian one.
identify, laminar, turbulent
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 14:11
How to change from mass flow to volume flow rate stanley FLUENT 1 February 2, 2007 07:44
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 09:42
Boundary Layer Flow Paradox Wen Long Main CFD Forum 3 September 24, 2002 09:47
