Error solving: Interpolating onto the new mesh |
April 5, 2011, 08:03 |
Rep Power: 15 |
Im trying to solve an easy duct problem. It just a heat transfer between the fluid with a combustion and the solid. And I get just a known error: | Memory Allocated for Run (Actual usage may be less) | +--------------------------------------------------------------------+ Data Type Kwords Words/Node Words/Elem Kbytes Bytes/Node Real 5138.8 49.40 12.59 20073.5 197.59 Integer 6305.2 60.61 15.45 24629.7 242.44 Character 392.0 3.77 0.96 382.8 3.77 Logical 19.6 0.19 0.05 76.6 0.75 Double 237.9 2.29 0.58 1858.3 18.29 +--------------------------------------------------------------------+ | ********* WARNING ********* | | The initial values file does not contain any field solution data. | | Please check the source file carefully. | +--------------------------------------------------------------------+ +================================================= ===================+ | ****** PROBLEM REPORT ****** | |--------------------------------------------------------------------| | Subsystem: Input | | Subroutine name: ErrAction | | Severity level: Fatal Error | | Error message number: 001100279 | |--------------------------------------------------------------------| | Message: | | | | Stopped in routine CHECK_INTERP | | | | | | | | | | | +================================================= ===================+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | Error interpolating results onto the new mesh: C:\Program | | Files\ANSYS Inc\v121\CFX\bin\winnt-amd64\solver-hpmpi.exe exited | | with return code 1. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | The following user files have been saved in the directory | | C:\Users\ing\AppData\Local\Temp\serp_tubofluido_co mbs_4872_Workin- | | g\dp0\CFX\CFX\Work1\Fluid Flow_001: | | | | job | +--------------------------------------------------------------------+ This run of the ANSYS CFX Solver has finished. ------------- I have tried a lot of things. First, I have an 8 Gb of RAM so it shouldnt have to be my problem. I have change on the "interpolator" tab the value to 1.4 and nothing. Any idea? |
April 5, 2011, 18:45 |
Rep Power: 144 |
The error message is pretty obvious to me. You have not specified an initial condition. You need to specify an initial condition which is physically meaningful.
April 6, 2011, 07:40 |
Rep Power: 15 |
April 6, 2011, 15:06 |
Rep Power: 17 |
Guess workbench 12.1 or below. Am I right?
- - - - - ------------------------------------------------------------------------ Please do not forget: I am not paid for answering your questions. Thousands of issues can cause a division by zero. Please do not capture a thread, with the argument: "I have the same issue ...." |
April 7, 2011, 03:25 |
Rep Power: 15 |
You´re right.
April 11, 2011, 13:14 |
Rep Power: 17 |
Hi Neusier, sorry was not here for some days.
As I updated to 13.0 this issue vanishes. Possibly a bug which is fixed now. If it is not possible to do the update, contact the service.
April 13, 2011, 04:02 |
Rep Power: 15 |
At last I changed the mesh, I did it better and the problem vanished. The Max skewness below 0.8 is my friend
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel | colinB | OpenFOAM Meshing & Mesh Conversion | 14 | December 12, 2018 08:07 |
[ICEM] how to mesh a sail (and the rest of the boat) | matteoL | ANSYS Meshing & Geometry | 4 | May 7, 2012 10:23 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 13:40 |
2d irregular grid | Remy | Main CFD Forum | 1 | December 22, 2008 04:49 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
