Slip Reynolds Number in multiphase simulation
Old   April 4, 2011, 13:51
Default Slip Reynolds Number in multiphase simulation
Pang
ukbid is on a distinguished road
Hello everyone,
I am doing a Euler-Euler two phase simulation (Water with dispersed air bubbles) with CFX. In my Solver Out file there is an "Air l Water Slip Reynolds Number" in the Average Scale Information. What does this number meanns and most important how is it calculated by the Solver???
Any replies will be highly appreciated!
Thanks a lot in advance!
ukbid is offline   Reply With Quote
Old   April 4, 2011, 20:17
It is the Reynolds number of the air bubbles, with the length scale being the bubble diameter and velocity being the slip velocity.
Old   April 5, 2011, 10:09
Pang
Thanks a lot Glenn!
But I am still not quite clear about the porblem. So for instance, i got the following Average Scale Information:
| Average Scale Information |
Domain Name : Default Domain
Global Length = 1.0873E-01
Minimum Extent = 4.0000E-02
Maximum Extent = 7.7000E-01
H2O.Density = 9.9700E+02
H2O.Dynamic Viscosity = 8.8990E-04
H2O.Velocity = 2.6129E-01
H2O.Advection Time = 4.1611E-01
H2O.Reynolds Number = 3.1828E+04
H2O.Mass (Conservative) = 1.1328E+00
H2O.Mass (Normalised) = 1.1332E+00
H2O.Volume = 1.1366E-03
H2O.Volume Fraction = 8.8434E-01
Air.Density = 1.1850E+00
Air.Dynamic Viscosity = 1.8310E-05
Air.Velocity = 4.9441E-01
Air.Advection Time = 2.1991E-01
Air.Reynolds Number = 3.4790E+03
Air.Mass (Conservative) = 1.7597E-04
Air.Mass (Normalised) = 1.7616E-04
Air.Volume = 1.4866E-04
Air.Volume Fraction = 1.1566E-01
Air | H2O.Slip Reynolds Number = 1.9725E+03
The bubble diamter = 6 mm = constant
So Slip velocity = Air.Velocity - H2O.Velocity = 4.9441E-01 - 2.6129E-01= 0.23312 m/s (am I right?)
Slip Reynolds Number = Slip Velocity * Bubble Diamter * H2O Density / H2O Viscosity = 0.23312 m/s * 0.006 m * 997 kg/m^3 / 0.000899 Pas = 1551.
This is still different than the value 1.9725E+03 given by the Solver.
Looking forward to your reply!!
Thanks a lot!!
Old   April 5, 2011, 19:47
The slip velocity is a vector. You cannot simply subtract two vectors like that, you need to take the direction into account.
Old   April 6, 2011, 10:16
vidhya is on a distinguished road
hi,
i need one very basic clarification.. generally euler-euler model is used wherein the stationary frame of reference is chosen and the equations solved. if we have two frames, one rotating and the other stationary then how will it be solved..? eg like a stationary tank and rotating turbine in reactors.. pls clarify
vidhya is offline   Reply With Quote
Old   April 6, 2011, 19:49
The frame of reference is a totally different thing to the multiphase formulation. The multiphase model can be used in rotating frames of reference and all the additional terms are taken care of. See the CFX documentation for details.
Old   April 8, 2011, 06:45
Pang
First thanks a lot again Glenn, for the help and information
And second to vidhya, I think CFX has a tutorial example about a mixing tank, where gas bubbles flow upwards in a tank and something is also moving inside the tank (sorry I can't remember quite clear). Just check the tutorial documentation, maybe you can find something useful.
Old   April 10, 2011, 23:51
hi ya,
thanks.. i got it.
Obtaining Reynolds Number in FLUENT Emmanuel FLUENT 2 April 7, 2016 02:46
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Changing Reynolds Number pvt FLUENT 0 June 7, 2009 01:11
courant number for hvac simulation Chilli83 CFX 1 May 5, 2009 21:39
Low Reynolds number K-Omega modeling Athar Zaidi Main CFD Forum 0 October 31, 1999 14:59
