Reaction rate too slow
Old   March 30, 2011, 12:48
Default Reaction rate too slow
K. D.
drb764 is on a distinguished road
Hello.
I try to simulate combustion in a porous structure using eddy dissipation model. Convergence is okay, but the reaction rate is too small. The combusion should be (nearly) completed at the burner outlet, but the ch4 mass fraction is only half the inlet value. Is there a way to speed up the reaction?
THANK YOU A LOT IN ADVANCE!
drb764 is offline   Reply With Quote
Old   April 6, 2011, 14:49
joey2007 is on a distinguished road
Standard values are adjusted to standard cases without porous media. Increase EDM A and EDM B, will increase reaction rate.
Please do not forget: I am not paid for answering your questions.
Thousands of issues can cause a division by zero. Please do not capture a thread, with the argument: "I have the same issue ...."
joey2007 is offline   Reply With Quote
Old   April 6, 2011, 14:51
K. D.
thank you joey!
Old   September 16, 2011, 08:44
m
riccia is on a distinguished road
I am also trying to simulate reactions in porous medium but i do not get even half conversion of species.
I cannot find anything on the internet about mixing rates and how to change them logically.
I would be glad if you could give me some insights.
Thank you,
Mehtap
riccia is offline   Reply With Quote
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 17:55
UDF for catalyst volumetric reaction, temperature overshoot though rate is small elmcmaster FLUENT 0 October 11, 2010 10:37
surface reaction rate with udf yellow-stuff FLUENT 4 January 29, 2010 13:53
UDF changing the rate exponent of a reaction Stefan H Fluent UDF and Scheme Programming 0 September 16, 2009 14:20
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 01:07
