manifold to many small channel design
Old   March 24, 2011, 15:46
Default manifold to many small channel design
mullenc525 is on a distinguished road
I'm designing a manifold for a device similar to a heat exchanger consisting of many small channels, about 300-3000 depending on the scale of the device and whether I decide upon a symmetrical design or not.
Currently I am attempting to mesh the channels with sweep then use an unstructured mesh on the manifolds. This is OK but I cannot figure out how to make the mesh connections 1:1. I am importing a solidworks assembly into CFX-mesh so I have separate 3D regions to mesh. I am unsure of which feature will force the mesh to be 1:1 and uncertain whether an assembly is the most appropriate method to import this geometry.
Also, I have a gut feel the design of the inlet side manifold is much more important than the outlet manifold. I'd like to do some work where I model only the manifold, and each channel is a 2-D region where the pressure on that face is a function of the flux through that region. How can I easily set this up for 300-3000 regions?!
mullenc525 is offline   Reply With Quote
Old   March 24, 2011, 16:26
It just occured to me that the gaps between the channels probably don't matter much since there are so many channels, on a big scale that surface might behave quite similar to a porous sheet. Does anybody have any opinion on modelling the surface where the channels begin as a porous sheet with an appropriate pressure drop per flux?
Old   March 24, 2011, 21:36
Exactly.
So get the resistance of the structure - either experimentally or with a CFD simulation of a single channel, then apply that to the big model as a resistance. You might consider an anisotropic resistance in this case as it looks different in the X and Y directions.
Old   March 31, 2011, 17:54
I have this working fairly well, though I have to use the non physical expert parameter 1 for porous cs discretization to make it converge - I'm not sure what impact that will have on my solution.
Now I'm wondering how to evaluate the flow distribution through the porous interface quantitatively. Is there anything like a variance function built in? How could I enter this manually in an expression?
Old   April 1, 2011, 06:06
By variance do you mean statistical variance? No, that is not built in.
Old   April 1, 2011, 13:55
Is there a better way to quantitatively evaluate flow distribution?
How can I enter something like statistical variance?
I'm not familiar with the fortran features if those are required, I know I need something like an expression:
sum over all locations of (Velocity w(some location)-areaAve(Velocity w )@Domain Interface 1 Side 1)^2
Old   April 3, 2011, 07:56
You should be able to write this as a CEL expression - and it looks like you have just about done it yourself. Are you able to get it working from there? What is your question?
Old   April 4, 2011, 16:12
I'm not sure how to sum over all locations in CEL or how to specify the arbitrary location to evaluate velocity w for any given part of that sum.
Old   April 4, 2011, 20:15
What do you mean by sum? Do you mean integrate - there are functions to do that. Do you mean sum - again, functions to do that. Or simply add a few cases together - well that is simply addition.
Read the CFX CEL reference guide for available commands and functions. I think everything you want will be in there.
micro channel heat exchanger design serpil kaya Main CFD Forum 6 March 25, 2018 08:34
exhaust manifold cfd design irfan FLUENT 2 September 5, 2013 17:22
CFD package for small propeller turbine design Drona Upadhyay Main CFD Forum 13 November 17, 1999 00:20
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
CFD - Trends and Perspectives Jonas Larsson Main CFD Forum 16 August 7, 1998 17:27
