March 24, 2011, 00:11 |
How to put residuals as a variable
mohammad
Rep Power: 16 |
Hi every body
In the FAQ section of Ansys cfx about the convergence problem , I found this tip:" Do a test run with the residuals in the result file ...." Could you please tell me how to put residuals as a variable for later investigation? Regards |
March 24, 2011, 08:43 |
Rep Power: 21 |
It's in CFX-Pre under "Output Control > Results".
March 27, 2011, 05:02 |
mohammad
Rep Power: 16 |
Hi stumpy,
I ticked the "Output Equation Residual " and I chose "ALL". then, under Monitor Option > Monitor option > Monitor residual >" Full ". After the run, In CFX-Post, I created a "Contour" and as a " Variable" to be assigned to that Contour , I just found . is "P-Mass Residual" that variable that FAQ meant? or else what's wrong in the process above. TNX a lot |
residuals |
emag beta feature: charge density | charlotte | CFX | 4 | March 22, 2011 10:14 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 05:35 |
Problems with additional variable | Krishna Premi | CFX | 1 | October 29, 2007 09:19 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 05:27 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
