Simulating Chapter 19 Air Conditioning Simulation
Old   March 22, 2011, 03:09
Default Simulating Chapter 19 Air Conditioning Simulation
Ji Guozhao
jiguozhao is on a distinguished road
Dear All:
I was trying to simulate the case in chapter 19 air conditioning in tutorial.
But I can not pass through the step of "Compiling the fortran subroutine for the thermostat". when it comes here, there is a error appeared as "ERROR CCL parser failed with message Perl Syntax errors detected: cfx5mkext failed at (eval 196) line 1". if i type "cfx5mkext TStat_Control.F" in the command line in laucher-tool, the error is "the complier command 'ifort' could not be found, pls ensure that the complier is on your path and try again". actually i do not know what is 'ifort'. I tried to add the whole file cfx/<bin> into my environment variable. but it is the same.
My computer system is Windows 7, and i installed compaq visual fortran 6.
I really do not know what is the reason of the problem. It drove me insane!
is there anyone who can give me an answer?
thanks very much in advance!!!
Ji Guozhao
g.ji@uq.edu.au
jiguozhao is offline   Reply With Quote
Old   March 22, 2011, 14:55
joey2007 is on a distinguished road
Guess on windows only intel is supported. Some month ago it was possible to get a 14-day test version from intel. If this is still possible, it may helps just for the tutorial.
Please do not forget: I am not paid for answering your questions.
Thousands of issues can cause a division by zero. Please do not capture a thread, with the argument: "I have the same issue ...."
joey2007 is offline   Reply With Quote
Old   March 22, 2011, 17:37
Ji Guozhao
Thank you Joey:
Sorry for my limited knowledge in Fortran, I don't know what is intel. Do you mean there are two kinds of fortran, one is intel fortran and the other is compaq fortran? and I installed compaq fortran. so this is the problem? If so I will buy a intel fortran. I really need to use fortran to interfere CFX.
Thank you very much!
with regards
Ji Guozhao
g.ji@uq.edu.au
Old   March 23, 2011, 14:38
Ugly Kid Joe
vmlxb6 is on a distinguished road
Compaq and intel FORTRAN are different types of FORTRAN compiler available. FORTRAN is a language, but you need a compiler to compile your source code. CFX is compatible with iFORTRAN (thats by intel). If you using a LINUX M/c like Ubuntu or Red-hat, you may require a different compiler. There are tonnes of them available. Try the trial version of iFORTRAN available for 30 days.
Hope that helps.
vmlxb6 is offline   Reply With Quote
Old   March 24, 2011, 17:59
Ji Guozhao
Hope that helps.
Thank u friend:
In CFX solver modeling guide, page 398 the 2nd paragraph, it said "a supported linked is required". What is that, do I have to install that? And how can I get that?
Thanks again!
With regards
Ji
Old   March 24, 2011, 18:01
Ugly Kid Joe
YES !!!!!! You do have to install an iFORTRAN in your system.
Old   March 25, 2011, 02:13
Ji Guozhao
Dear Friend:
i am sorry to bother you again!
can u provide me a link of iFORTRAN? I can not find that in google.
regards
Ji
Old   March 25, 2011, 02:38
Ugly Kid Joe
https://registrationcenter.intel.com...8GWJ7R%810%842
Old   March 28, 2011, 23:37
Ji Guozhao
Dear friend:
I downloaded that, and installed on my computer. but it is still not able to compile the Fortran file. is it just installing CFX and Fortran? do i need to set some other things afterwards? can you help me solve this problem?
kind regards
Ji Guozhao
Old   March 29, 2011, 02:57
Ugly Kid Joe
I am sorry . I wish I could help you with it. My college computer already had everything installed so I never had to face these kinda of problems. You need to ask someone else.
Prof. Chaos
Old   March 29, 2011, 15:15
There are some hints on requirements and setup in the help. Check it.
Simulation of air flow in a chamber Issa CFX 3 November 23, 2009 18:16
Simulation of a mixture of air / CNG (compressed natural gas) jonmec OpenFOAM Pre-Processing 0 November 13, 2009 15:24
CFX Air conditioning Simulation_expression help!!!! Urgen!!! yin2 CFX 6 March 31, 2009 00:34
Simulation of Car Cabin Air Flow Erwin Susanto Main CFD Forum 0 May 19, 2000 12:33
air jet simulation Yue zou Main CFD Forum 0 September 28, 1998 09:30
