convergence criteria by lift and drag coefficent
Old   March 17, 2011, 06:37
Default convergence criteria by lift and drag coefficent
xtof is on a distinguished road
I have modelled a flow over an airfoil in cfx which works fine so far. Futhermore i have created monitorpoints for lift- and drag-coefficent.
What i want to do now is to set a interrupt control condition in cfx pre so that the actual value of the coefficent is compared to the one ten iterations before. If the difference is under a defined limit (let's say 0.1%) the simulation should be stoped.
My problem is that I don't know the CEL-Syntax to get a value at a certain iteration.
Maybe somebody knows how to program that.
Thanks
xtof is offline   Reply With Quote
Old   March 18, 2011, 07:44
This cannot be done easily in CEL.
You will probably find a residual convergence tolerance to correspond to your coefficient convergence. Then you could just use a simple residual convergence tolerance.
If you insist on using your coefficients to judge convergence then I would have a cron job running in the background (ie outside of CFX) which monitors the monitor point output files and when it senses convergence it runs the cfx5stop command.
Old   March 18, 2011, 07:50
Thanks for the reply. I think I'll go with the normal residuals so far. I had a phoncall with the CFX-Support yesterday and they told me the same. Maybe when I have more time I'll try to pragramm some tool to monitor the coeffiecents and stop the solver run.
Old   March 18, 2011, 15:38
joey2007 is on a distinguished road
The service send me an user fortran example, which stores older values, some time ago. I am not permitted to distribute further, however you may get it if you ask.
Please do not forget: I am not paid for answering your questions.
Thousands of issues can cause a division by zero. Please do not capture a thread, with the argument: "I have the same issue ...."
joey2007 is offline   Reply With Quote
cel expression, coefficient, convergence, drag, lift
Lift and Drag ??? Yogibear STAR-CCM+ 5 November 2, 2023 18:14
Lift and Drag Monitor Point Values Converging to Zero Josh CFX 24 May 9, 2011 11:38
Correct lift but wrong pressure drag - possible? zx Main CFD Forum 4 July 28, 2007 00:38
drag and lift coefficient Noé Siemens 5 July 13, 2004 11:21
Fluid mechanics / drag & lift Jamcam Main CFD Forum 0 October 31, 2002 05:39
