Resistance Loss Coefficient
Old   March 13, 2011, 10:53
Default Resistance Loss Coefficient
K. D.
drb764 is on a distinguished road
can someone tell me how to calculate the "Resistance Loss Coefficient" and/or the "Linear Resistance Coefficient" for use in the CFX Porosity Settings Tab?
Found nothing on the web unfortunately, so thanks a lot in advance!
drb764 is offline   Reply With Quote
Old   March 13, 2011, 19:01
You use the coefficients to match a porous medium to experimental results. Do youy have experimental results?
Old   March 13, 2011, 23:44
Ji Guozhao
jiguozhao is on a distinguished road
make use of you experiment data of pressures and velocities. you can refer the equation 1.146 in ANSYS CFX-Solver Theory Guide, at page 33. then you can obtain Kperm and Kloss via your experimental data. you can contact me if you like, because i just studied that days ago.
g.ji@uq.edu.au
jiguozhao is offline   Reply With Quote
Old   March 14, 2011, 07:14
K. D.
what i have are the laminar and turbulent permeabilities k1 and k2 which correspond to this equation:
dP/L = mu/k1 * U + rho/k2 * U^2
Looks similar to the equation in Solver Theory Guide, but are these the values I need?
Thank you so far!
Old   April 21, 2014, 03:28
will321321 is on a distinguished road
Hi Gentlemen,
I am on the process of calculating the Linear & Quadratic loss coeff. Via experimental Data (V vs P) but the equation im getting from the graph is giving a negative (-) Value for permeability.
Please Help me remedy this problem.
Thank you very Much.
-will
will321321 is offline   Reply With Quote
Quadratic resistance Coefficient Ramana CFX 4 November 26, 2012 17:25
Porous loss model coefficient query siw CFX 7 August 24, 2011 08:41
viscous and internal resistance coefficient in porous media bansal_vikas1 FLUENT 12 October 6, 2010 09:28
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
Quadratic Resistance Coefficient Ramana CFX 0 January 2, 2006 04:43
