Solver problem in Oscillating Plate tutorial
Old   March 3, 2011, 21:55
Question Solver problem in Oscillating Plate tutorial
vovogoal is on a distinguished road
Im trying to follow the Tut23 Oscillating Plate to start FSI. Each steps have been exactly followed. But I couldnt ignite the solver. ANSYS tackled me down several times with following,
Ans.Core.Commands.UserReadableFailure: The CFX Solver for system Fluid did not produce a results file. No output file is available.
at Ans.CFX.CFXCore.Data.CFXSolutionSource.HandleRunFa ilure(CommandContext context, CFXSolverRun run, String rawSolverOutput)
at Ans.CFX.CFXCore.Data.CFXSolutionSource.RunSolver(C ommandContext context, Boolean forceResume)
at Ans.CFX.CFXCore.Commands.UpdateSolutionCommand.Exe cute(CommandContext context)
at Ans.Core.Commands.Concurrency.CommandWorkUnit.exec uteInContext(CommandContext subContext, IExecutionEngineCallback tracer)
at Ans.Core.Commands.Concurrency.BaseWorkUnit.doExecu te(IExecutionEngineCallback executionEngine, CommandContext subContext)
at Ans.Core.Commands.Concurrency.BaseWorkUnit.Execute (IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions)
--- Ans.Core.Commands.CommandFailedException: The CFX Solver for system Fluid did not produce a results file. No output file is available.
Command: CFX.UpdateSolution(Container="Solution 1")
at Ans.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext)
at Ans.Core.Commands.CommandAsyncResult.Wait()
at Ans.ProjectSchematic.Data.ComponentTemplateEntity. Update(CommandContext context, IProgressMonitor progressMonitor, DataContainerReference container, List`1 downstream, List`1 allRemaining)
at Ans.ProjectSchematic.Update.UpdateImpl.updateCell( CommandContext context, UpdateTask task)
at Ans.ProjectSchematic.Update.UpdateImpl.<>c__Displa yClass19.<updateCellAndDependencies>b__18()
at Ans.ProjectSchematic.Update.UpdateImpl.executeWith SelectedErrorBehaviour(Op op, UpdateTask forTask)
at Ans.ProjectSchematic.Update.UpdateImpl.updateCellA ndDependencies(UpdateTask task, Boolean& didSomething)
at Ans.ProjectSchematic.Update.UpdateImpl.checkAndUpd ateCell(UpdateTask task, Boolean& didSomething)
at Ans.ProjectSchematic.Update.UpdateImpl.doOutstandi ngTasks(IEnumerable`1 tasks, Boolean& didSomething)
--- System.InvalidOperationException: Update of the Solution cell in Fluid failed: The CFX Solver for system Fluid did not produce a results file. No output file is available.
at Ans.ProjectSchematic.Update.UpdateImpl.<UpdateCell s>d__3.MoveNext()
at Ans.ProjectSchematic.Commands.UpdateComponentComma nd.<Execute>d__0.MoveNext()
at Ans.Core.Commands.Concurrency.SuspendableCommandWo rkUnit.executeInContext(CommandContext subContext, IExecutionEngineCallback tracer)
--- Ans.Core.Commands.CommandFailedException: Update of the Solution cell in Fluid failed: The CFX Solver for system Fluid did not produce a results file. No output file is available.
Command: UpdateComponent(Component="/Schematic/Component:Solution 1", Force=True)
at Ans.Core.Commands.CommandAsyncResult.WaitForSuspen dOrComplete(Int32 milliSecondsTimeout, Boolean exitContext)
at Ans.CFX.CFXCore.Commands.UpdateFromSolverManagerGu i.Invoke(GuiOperationContext context)
at Ans.UI.UIManager.<>c__DisplayClass9.<InvokeOperati on>b__8()
at Ans.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages)
Could anyone has idea what Ive done wrong?
Many Thanks!!!
vovogoal is offline   Reply With Quote
Old   November 22, 2011, 10:54
Default FSI Error Tutorial 23
Ted Vaughan
tvghn is on a distinguished road
I'm getting the same error
"The CFX solver for the system Fluid did not produce a results file. No output file is available. Cell B5"
Wondering if you managed to fix this problem?? I'm running ANSYS 12.1 on 64 bit windows and it's the academic teaching license...dunno if this is the problem....any help would be great? Thanks
tvghn is offline   Reply With Quote
cfx
Creating New Solver: For particle-laden compressible jets sankarv OpenFOAM Running, Solving & CFD 17 December 3, 2014 20:41
Moving mesh problem with a FSI solver mathieu OpenFOAM Running, Solving & CFD 8 January 25, 2010 10:08
CFX 11 x64 solver? problem Attesz CFX 6 June 7, 2009 09:37
Coupled solver energy equation problem lucioantonio FLUENT 0 April 3, 2009 11:21
problem about direct solver for sparse matrix ztdep Main CFD Forum 0 August 11, 2006 13:16
