When to use local timescale or physical timescale
Like Tree5Likes
Old   June 25, 2014, 08:41
Default local timescale weird convergence
  #21
Daniel Frederik
Daniel Frederik is on a distinguished road
Hi everybody,
Simulating a radial gas turbine a came to this case which is very hard to make converge.
Just to get a feeling of what the different timesteps will do i simulated with different ones. In the picture there are the convergence criterions plottet with different timesteps. The last one, the local timestep, looks weird. I saw that before in another case. Why does it not converge donewards. It looks like it would converge to a "convergence criteria which doesn't make sense.
Any Ideas?
Daniel Frederik is offline   Reply With Quote
Old   June 25, 2014, 08:45
Your simulation is clearly very numerically unstable. Local time stepping is not helping you much - so do not use it. Physical time stepping will probably work better for you.
That is why all these options are available - different simulations need different approaches.
Old   June 25, 2014, 08:47
Daniel Frederik
Thanks for your rapid answer Glenn,
Could it also be that it is phisically unstable instead of numerical? Because with different mass Flows and Speeds of revolution i don't have that sort of problem.
I mean, i am doing a steady state analysis, but what if the flow is unsteady. Thats what i mean with phisicaly unstable.
Old   June 25, 2014, 08:55
Yes, physical instability will result in numerical instability as well.
So if the flow is truly transient then a steady state run will be unstable. This is all explained in the FAQ this thread has linked to.
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
