October 18, 2016, 22:16 |
#41 |
Ahmed Elhanfi
Rep Power: 12 |
Please click the link below where you can find a paper hopefully solving this problem.http://ecite.utas.edu.au/110364
Thanks, Ahmed |
October 19, 2016, 04:04 |
#42 | ||
Paulus Sidabalok
Rep Power: 10 |
Do I need do finer mesh and timestep? Quote:
October 19, 2016, 04:23 |
#43 |
Ahmed Elhanfi
Rep Power: 12 |
Thanks Pawl,You should get it now. Please feel free to email me in case you still have problems.
Thanks, Ahmed |
October 19, 2016, 06:08 |
#44 |
Paulus Sidabalok
Rep Power: 10 |
October 19, 2016, 06:58 |
#45 | |
Rep Power: 144 |
December 26, 2016, 11:10 |
problem with wave damping in ansys fluent
#46 |
Rep Power: 12 |
I am using ansys v16.0 for wave generation simulation in a 2D numerical wave tank (x=50m *y=5m). A fixed float structure is located at the distance of 30m from the wave boundary condition. The problem is as follows:
whenever I implement a turbulence model (k-e RNG), the free surface elevation starts to be damped after about 90s simulation and after about 200s the wave height decreases drastically. however, when using laminar mode, I dont have this problem. Do you have any suggestion to solve my problem? |
December 26, 2016, 16:26 |
#47 |
Rep Power: 144 |
That is what turbulence models do, they model the extra dissipation from turbulence effects. Please post an image of the results of the model and what you expect to see. Do you have good experimental data to compare to?
December 26, 2016, 18:19 |
#48 |
Rep Power: 12 |
Dear Glenn
As it is shown in the attached pic, you can see a dissipation of wave height during the simulation time. the pic shows surface elevation for a point (6.3meters far from the floating structure) during the simulation time. after about 90s simulation you can see that the waves start to be damped. However in experimental results you cant see this issue. the model is 2D. wave height 0.22m and T=2s. when I use laminar model you cant see dissipation. On the other hand, it should be mentioned that I have already modeled wave tank without presence of the structure and could get good results both in laminar and turbulence models. in brief, I think that existence of the structure causes this damping and from available experimental results, I know that my simulation is wrong now. Thanks a lot. |
December 27, 2016, 06:26 |
#49 |
Rep Power: 144 |
I also note that your simulation is using Fluent. For details on Fluent try the Fluent forum. This is the cfx forum.
what is the condition to use the wave equation? | mmff | Main CFD Forum | 0 | January 26, 2010 05:25 |
Continuous vs interrupted simulation | sega | OpenFOAM Running, Solving & CFD | 4 | November 3, 2008 15:29 |
Breaking Wave Simulation | Mehdi BEN HAJ | Main CFD Forum | 2 | February 12, 2002 12:07 |
Breaking Wave Simulation | Mehdi BEN HAJ | CFX | 0 | February 9, 2002 13:34 |
Breaking Wave Simulation | Mehdi BEN HAJ | Siemens | 0 | February 9, 2002 13:32 |
