February 28, 2011, 13:51 |
1 Was FSI for a flow over a cylinder
Ugly Kid Joe
Rep Power: 16 |
I need help with this as I am stuck on this for a long time now. I am trying to find out the displacement of a cylinder in a cross flow. The cylinder is subjected to move in the transverse direction only. I am not getting correct displacements of the cylinder. I am using a CEL expression for Mesh deformation. To check my mesh and BC, I tried to run a transient case of a flow over a fixed cylinder and compared the results. They were alright. That means the Mesh, Boundary layer, physics of the problem, Boundary conditions are all fine. But when I use this mesh deformation, I cannot validate my results. My geometry simple. It is just a square domain with a circle at the centre (i.e 2-D) The CEL expression is very much similar to the CEL expression given in the tutorial Ch: 22 Fluid Struct interaction and mesh deformation. The only difference is that the tutorial has a spring while I also have a damper with the spring. I am attaching the pic of the mesh and the CEL expression am using. Any kind of suggestion is highly appreciated. Thank you. boundary layer.jpg mesh1.jpg CELexpression.txt |
February 28, 2011, 15:59 |
Rep Power: 16 |
I've done very similar calculations for turbulent flow, with some reasonable results.
Are the forces on the cylinder what you expect for the flow Reynolds Number? If they are in the right ball park, then it is a simple matter to calculate the free undamped vibration amplitude and compare it with what you get out of CFX. This will at least tell you if your expression formulation is right. |
February 28, 2011, 16:07 |
@ cfdgremlin
Ugly Kid Joe
Rep Power: 16 |
I have not compared the forces yet. What I presumed was that the displacements were low bcoz of low forces. Is there any papers/txt book etc with which I can compare my force data for a moving cylinder, to see if ???
I guess the forces on the stationary cylinder will be different from that of a moving cylinder. I tried running a stationary cylinder case (which did not involve FSI-mesh motion), and the forces/lift coeff were correct. Thank you for writing !!! Regards, Prof. Chaos |
March 1, 2011, 18:20 |
Rep Power: 144 |
Have you done all the normal sensitivity checks? Mesh, time step, convergence?
March 1, 2011, 18:30 |
Edmund Singer P.E.
Rep Power: 21 |
You can apply the motion to either a subdomain or the walls for this type of problem. Using a subdomain allows you to push the deformed mesh into a region that is better able to handle it. If you dont expect a large deformation, by all means move the walls.
Havent checked your ccl expressions but they should boil down to a=F/m after manipulation: dCYLINDERNew=(velCYLINDEROld+F/mCYLINDER*tstep)*tstep+dCYLINDEROld I think F in your case should be FFLow-C*velCYLINDEROld-k*dCYLINDEROld Which I dont have time to check if all this boils down to what you had in your num/dem ccl. You should monitor, at the very least, the following values to see if they make sense: FFLow C*velCYLINDEROld k*dCYLINDEROld And with the equations above mesh motion should be defined as Specified Displacement |
March 3, 2011, 04:19 |
@ Ghorocks & singer 1812
Ugly Kid Joe
Rep Power: 16 |
I used the same mesh to simulate the lift forces over a stationary cylinder. And it gave correct results. Doesn't that mean that the mesh is fine ???
The problem could be when the mesh deforms. The boundary layer near the cylinder walls also deform thus giving wrong results. (I dont know, Its just a wild guess.) Am using Mesh stiffness to increase near small volumes & stiffness model exponent = 2. Can that cause a problem ??? Should I be using 'increase near boundaries' ??? @ Ghorocks: The solution seems to be converging. The time step is small enough. The RMS courant is close to 0.22 & max courant is 0.7 How to check if the mesh is fine. My mesh is certainly fine for a transient stationary case. But how do I find out the same for a moving mesh ??? @singer: The cylinder wall does have specified displacement. How do I know if Fflow, C*vel or K*disp makes sense ??? |
March 3, 2011, 10:30 |
Edmund Singer P.E.
Rep Power: 21 |
You are to decide if they make sense or not.
Are you starting this from a solution interpolated from the non-moving mesh solution? Perhaps, FFLow should be close to the value from that, near the beginning for solution. At the start of solution I would guess that the spring and damping term should be small, and if the cylindar continues to not move much, should balance out FFlow. If that is not the case, maybe you have something messed up in your logic. |
March 4, 2011, 10:25 |
Ugly Kid Joe
Rep Power: 16 |
1. For a flow over a (moving) cylinder. If I scale my force i.e multiply by the length, should the 2-D case give the same result as that of a 3-D case.
2. For a transient case simulation, is 10^-4 a good convergence criteria ??? Or should I be reducing further. Thank you. Last edited by vmlxb6; March 6, 2011 at 16:27. |
March 6, 2011, 18:10 |
#9 | |
Rep Power: 144 |
March 6, 2011, 18:44 |
#10 |
Ugly Kid Joe
Rep Power: 16 |
Thanks Ghorrocks
March 15, 2011, 08:11 |
#11 |
Ugly Kid Joe
Rep Power: 16 |
I have run out of options. I have been trying this for a long time now but unable to match experimental values. Can anyone please have a look at my files as I have reached the dead end. Thank you. |
March 15, 2011, 14:49 |
#12 |
Rep Power: 16 |
Can I ask just a couple more questions:
1. Is this a laminar or turbulent flow simulation? 2. What are the details of the experiment? Are the results from a published paper? What are the end-load conditions? Is it a rigid or flexible cylinder? What fluid is used? etc ... 3. How far out are the displacements in the simulation compared to the experiment? Is it a factor of 2, 10, 100? Thanks |
March 15, 2011, 15:29 |
#13 |
Ugly Kid Joe
Rep Power: 16 |
Hey,
1. The experiments were run at Re = 525. Hence Laminar. 2. End load conditions ????? I have no idea 3. It is a rigid body 4. Published in Journal of fluid & structures They are getting A/D = 0.06 while am getting it as 0.03~0.04. In the CEL expression that I have attached, I have used a first order accurate forward differencing scheme. That may be the reason. I dont know it yet. Am still figuring it out. Thank you for responding. |
March 16, 2011, 12:17 |
#14 |
Rep Power: 16 |
Are you able to reveal the details of the paper (name, author, date)?
March 16, 2011, 12:50 |
#15 |
Ugly Kid Joe
Rep Power: 16 |
Name: On the maximum amplitude for a freely vibrating cylinder in cross-flow
Author: J.T. Klamo, A. Leonard, A.Roshko Journal: Journal of Fluids & structures 21(2005) 429-434 |
March 21, 2011, 13:35 |
#16 |
Rep Power: 16 |
I have only been able to read the abstract, but the authors are well renowned in the field.
In the simulations I have performed, both with using CEL expressions and 2-way FSI with ANSYS, it has been difficult to exactly match the experimental data (although mine were at higher Reynolds numbers). The maximum amplitude usually occurs at "lock-in", and this phenomena is associated with a sharp jump in amplitude ratio. I would recommend that you perform a number of simulations either side of your targeted conditions to see how the amplitude responds. Hope this helps. |
March 21, 2011, 14:05 |
#17 |
Ugly Kid Joe
Rep Power: 16 |
How are you doing a 2-way FSI ??? Does that mean that your Cylinder is deforming ?????
Can I have a look at your CEL expression ??? What discretization scheme are you using ??? Thanks |
May 16, 2011, 03:29 |
@ cfdgremlin
#18 |
Ugly Kid Joe
Rep Power: 16 |
Hey,
You mentioned that you used a CEL as well as a 2 way FSI. My question is, was the 2 way used to find the structural deformation of the cylinder ??? Thank you. |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 12:47 |
reference calcultion, flow around a cylinder | butch85 | Main CFD Forum | 3 | January 31, 2011 17:10 |
Flow over a flat plate & Flow over a cylinder | cfdxue | Main CFD Forum | 0 | November 27, 2007 00:26 |
Anybody knows smth abt the flow around a cylinder? | Wenxuan | Main CFD Forum | 3 | March 20, 2007 17:19 |
Flow over a cylinder | Anna | Main CFD Forum | 9 | March 24, 2006 15:32 |
