FSI problem , Help needed for my basic questions |
February 20, 2011, 04:23 |
Govindaraju
Rep Power: 17 |
Hi
I am doing Two way FSI problem. Can you please provide the steps from the development of the model to CFX post My questions are very basic : 1. SHALL I DO CFX MESHING (.gtm) BEFORE DO THE ANSYS INPUT FILE (.inp)? or 2. without doing CFX meshing(.gtm) can I do ANSYS input file (.inp)? Note :In the Tutorial, it has written like the following "The mesh is automatically generated as part of this process.If you want to examine it, select mesh from the tree" Kindly help me for this basic questions Regards kmgraju |
July 29, 2011, 01:04 |
Lingdeer
Rep Power: 15 |
I m not an experienced user for CFX. I just start using ANSYS workbench to do FSI with CFX. The ".inp" file should include all the structual mechanical data required to solve the fluid flow. So I would assume you need to import the geometry/mesh into it to create the ".inp" mechanical model, which is considered as input for the fluid solver.
Correct me if I am wrong. |
Free surface problem: hull mesh questions | albertofast | OpenFOAM | 2 | December 15, 2010 20:50 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 05:08 |
basic questions on residuals | Herrold | Main CFD Forum | 22 | February 10, 2008 01:15 |
Negative volume problem in Two-way FSI coupling | fred | CFX | 3 | August 16, 2006 11:03 |
Looking for a open FEM code to solve a FSI problem | Esto | Main CFD Forum | 3 | June 15, 2006 12:02 |
