Remeshing in FSI problem
Old   February 18, 2011, 17:17
Unhappy Remeshing in FSI problem
kesife
tctczxh is on a distinguished road
If CFX is used alone,the remeshing options can be set in
Simulation Control -> Configurations
however in FSI project created in workbench, the configurations submodule is disabled.
Does it mean automatic remeshing is still not possible in this kind
of FSI problem?
tctczxh is offline   Reply With Quote
Old   February 19, 2011, 00:00
kesife
hopefully there is a way to use ICEM CFD to remesh in FSI problems
Old   February 21, 2011, 16:26
Edmund Singer P.E.
singer1812 is on a distinguished road
FSI with remesh is not supported.
It can be done outside of WB using alot of Mechanical APDL and advanced modeling techniques that I care not to go into with someone not expert in both CFX and ANSYS APDL.
singer1812 is offline   Reply With Quote
Old   February 22, 2011, 14:28
kesife
Currently I deal with those FSI problems in workbench by enabling the mesh deformation option.
actually by adjusting the mesh stiffness and refining the mesh, the simulation works in some cases, but it's quite limited. the mesh quality degrades continuously then the solver is likely to be terminated by a folded mesh error.
so I'm confused that what should I do if I really need some structure displacement in FSI problems?
Old   February 22, 2011, 17:15
stumpy is on a distinguished road
There are certainly some cases that can't be solved with 2-way FSI because re-meshing is not really available. However there's a lot that can be done using mesh deformation. You can add sliding interfaces, control the stiffness, add subdomains with defined motion etc. Do you have some images of your initial and deformed mesh?
stumpy is offline   Reply With Quote
Old   February 28, 2011, 11:41
Ugly Kid Joe
vmlxb6 is on a distinguished road
heres the link for re-meshing:
http://www.edr.no/blogg/ansys_blogge...cfx_re_meshing
@ Singer1812: Why do you say that re-meshing is not possible in FSI Problem ?
@ Kesife: There are a couple of post where people have addressed the issue of folding mesh. It can be solved by reducing time step, better converging of displacement Eq. etc etc Even I had folding mesh issues but that was because I was using unrealistic values. For structural deformation, try 2-was FSI
@ ALL : Looks like you guys are pretty familiar with FSI. Am modeling a one way FSI for a flow over a cylinder and have a few questions. I will post it in a new thread. I hope to get them answered.
Thank you,
Prof. Chaos
vmlxb6 is offline   Reply With Quote
Old   February 28, 2011, 11:45
Edmund Singer P.E.
I didnt say remeshing is not possbile, remeshing in FSI witin ANSYS is not supported.
You will have to use alot of APDL and model manipulation in order to get a remeshed FSI problem to work.
Old   February 28, 2011, 11:49
Edmund Singer P.E.
Ahh, I see where the confusion is.
I took this FSI question to be a case where structural deformation was the underlying cause of the fluid mesh movement, with a coupled structral FEA and CFD analysis used.
Just predicting rigid body motion in CFD can use remeshing with no issues.
Old   February 28, 2011, 11:58
Default @Singer1812
Ugly Kid Joe
Ahh...........I get it now.
Correct me if am wrong.
Re-meshing in a One way FSI is possible, where the motion of the rigid body motion can be predicted.
But Re-meshing in a 2 way FSI (structural deformation) is difficult.
Am I right ??????????
BTW wats APDL ????
Old   February 28, 2011, 12:07
Edmund Singer P.E.
What you said is correct.
APDL is the programming (scripting) language that the mechanical side (finite element) of ANSYS uses.
It stands for ANSYS Parametric Design Language
Old   February 28, 2011, 12:14
Default @singer182:
  #11
Ugly Kid Joe
Cool !!!!!!!!! Thanks Dude........... have a nice day.
Another favor: I am trying to model a 1-way FSI problem of a flow over a cylinder. Am getting very low values of displacement. I will be posting a thread. I hope you could answer a few of them.
Old   September 25, 2014, 12:10
Gwen Yang
gwen520 is on a distinguished road
hello,vmlxb6,recently,I tried the example posted above http://www.edr.no/blogg/ansys_blogge...cfx_re_meshing
but after lots of trails, I still failed.Did you ever do that example? if you do,can you give your CFX file to me for reference. my email is 15262904691@163.com
thank you very much!
gwen520 is offline   Reply With Quote
Old   September 25, 2014, 12:11
Gwen Yang
hello,singer1812,recently,I tried the example posted above http://www.edr.no/blogg/ansys_blogge...cfx_re_meshing
cfx, fsi, remesh
initial file for fsi modeling? mortazavi CFX 0 July 21, 2009 03:06
problem in solving fsi simulation siavash CFX 5 July 10, 2009 12:59
Problem with FSI simulations ufuk CFX 0 October 11, 2006 09:16
Negative volume problem in Two-way FSI coupling fred CFX 3 August 16, 2006 11:03
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 09:40
