How to start CFX Solver with an existing parfile
Old   February 18, 2011, 06:14
Default How to start CFX Solver with an existing parfile
sirLentschi
lentschi is on a distinguished road
Hello everyone,
i want to split my Solver-process in 2 divisions:
At first, cfx should ONLY produce a partitioning file <parfile>. That's quite easy to perform with the "part-only" command.
Afterwards I want to read in this <parfile> and then to start the solver.
Therefore I used following commands:
cfx5solve -def test.def -part-only 24
and then in another script:
cfx5solve -def test.def -parfile-read test.par
cfx5solve -def test.def -par-dist <host-list> -start-method "HP MPI Distributed Parallel" -double -name tmp -ccl upwind.ccl
cfx5solve -def test.def -par-dist <host-list> -start-method "HP MPI Distributed Parallel" -double -ini Upwind.res
Or should I put the parfile-read command and the -par-dist in one line like this:
cfx5solve -def test.def -parfile-read test.par -par-dist 24 -start-method "HP MPI Distributed Parallel" -double -name tmp -ccl upwind.ccl
cfx5solve -def test.def -par-dist 24 -start-method "HP MPI Distributed Parallel" -double -ini Upwind.res
The Solver should perfom some "Upwind" steps and then switch to "High Resolution"
Without this splitting of the partitioning part, the Solving works!
Thanks in advance.
Regards Markus
lentschi is offline   Reply With Quote
Old   February 18, 2011, 09:17
Thumbs up
sirLentschi
I got it:
to partition only:
cfx5solve -def test.def -part-only #Partitions
and then to solve:
cfx5solve -def test.def -par-dist #CPUs -parfile-read <parfile> -start-method "HP MPI Distributed Parallel" .......
Old   February 18, 2011, 22:35
Default Hi
Dynampally Pavitran
pavitran is on a distinguished road
What is the advantage of this method when compared with default partitioning command "-part" ?
pavitran is offline   Reply With Quote
Old   February 20, 2011, 14:31
joey2007 is on a distinguished road
If you change nothing in the mesh, it is possible to reuse the par-file. This means can save the time for the partitioning.
Please do not forget: I am not paid for answering your questions.
Thousands of issues can cause a division by zero. Please do not capture a thread, with the argument: "I have the same issue ...."
joey2007 is offline   Reply With Quote
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 10:52
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
CFX start problem, "Appwindow" Attesz CFX 4 September 27, 2009 06:06
CFX 11, solver Debabrata CFX 1 June 16, 2008 22:52
CFX 5.5 Roued CFX 1 October 2, 2001 17:49
