sam13
Rep Power: 17 ![]() |
Hi everybody,
I was running a transient simulation for Maximum number of time-step iterations of 480. Since my simulation did not converge, I wish to continue the simulation for up to 720 timesteps. I am wondering how can I do that? I modified the definition file and set the new Max. time steps to 720. But it did not work. The simulation stopped just after one time steps showing the message " Maximum number of time-step iteration has been reached"; though it was supposed to continue until 720 time-step iterations. Any suggestion will be highly appreciated. |
sam13
More informations:
I'm using CFX V11.0. I followed the CFX manual for "Restarting a run" and same thing happened. I badly need help to fix it. Thanks in advance. |
Rep Power: 144 ![]() ![]() ![]() ![]() |
Can you post your CCL?
Did you start your run with modified def-file or with the res-file? Or did you modify your res-file before starting?
sam13
Thanks for your reply. Here is the CCL:
+--------------------------------------------------------------------+ | | | CFX Command Language for Run | | | +--------------------------------------------------------------------+ LIBRARY: MATERIAL: Water Material Description = Water (liquid) Material Group = Water Data, Constant Property Liquids Option = Pure Substance Thermodynamic State = Liquid PROPERTIES: Option = General Material Thermal Expansivity = 2.57E-04 [K^-1] ABSORPTION COEFFICIENT: Absorption Coefficient = 1.0 [m^-1] Option = Value END DYNAMIC VISCOSITY: Dynamic Viscosity = 8.899E-4 [kg m^-1 s^-1] Option = Value END EQUATION OF STATE: Density = 997.0 [kg m^-3] Molar Mass = 18.02 [kg kmol^-1] Option = Value END REFERENCE STATE: Option = Specified Point Reference Pressure = 1 [atm] Reference Specific Enthalpy = 0.0 [J/kg] Reference Specific Entropy = 0.0 [J/kg/K] Reference Temperature = 25 [C] END REFRACTIVE INDEX: Option = Value Refractive Index = 1.0 [m m^-1] END SCATTERING COEFFICIENT: Option = Value Scattering Coefficient = 0.0 [m^-1] END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 4181.7 [J kg^-1 K^-1] Specific Heat Type = Constant Pressure END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 0.6069 [W m^-1 K^-1] END END END END FLOW: SOLUTION UNITS: Angle Units = [rad] Length Units = [in] Mass Units = [lb] Solid Angle Units = [sr] Temperature Units = [R] Time Units = [s] END SIMULATION TYPE: Option = Transient EXTERNAL SOLVER COUPLING: Option = None END INITIAL TIME: Option = Automatic END TIME DURATION: Maximum Number of Timesteps = 720 Option = Maximum Number of Timesteps END TIME STEPS: Option = Timesteps Timesteps = 0.000264383 [s] END END DOMAIN: Default Domain Coord Frame = Coord 0 Domain Type = Fluid Fluids List = Water Location = Primitive 3D, Primitive 3D 2, Primitive 3D 3 BOUNDARY: Domain Interface 1 Side 1 Boundary Type = INTERFACE Location = Primitive 2D 2,Primitive 2D,Primitive 2D 3 BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = Conservative Interface Flux END TURBULENCE: Option = Conservative Interface Flux END END END BOUNDARY: Domain Interface 1 Side 2 Boundary Type = INTERFACE Location = Primitive 2D A 3,Primitive 2D A 2,Primitive 2D A BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = Conservative Interface Flux END TURBULENCE: Option = Conservative Interface Flux END END END BOUNDARY: bladepre Boundary Type = WALL Frame Type = Rotating Location = BLADEPREBC 2,BLADEPREBC 2 2,BLADEPREBC 2 3 BOUNDARY CONDITIONS: WALL INFLUENCE ON FLOW: Option = No Slip WALL VELOCITY: Angular Velocity = 0 [rev s^-1] Option = Rotating Wall END END END END BOUNDARY: bladesuc Boundary Type = WALL Frame Type = Rotating Location = BLADESUCBC 2,BLADESUCBC 2 2,BLADESUCBC 2 3 BOUNDARY CONDITIONS: WALL INFLUENCE ON FLOW: Option = No Slip WALL VELOCITY: Angular Velocity = 0 [rev s^-1] Option = Rotating Wall END END END END BOUNDARY: hub Boundary Type = WALL Frame Type = Rotating Location = HUBBC,HUBBC 2,HUBBC 3 BOUNDARY CONDITIONS: WALL INFLUENCE ON FLOW: Option = No Slip WALL VELOCITY: Angular Velocity = 0 [rev s^-1] Option = Rotating Wall END END END END BOUNDARY: inlet Boundary Type = INLET Frame Type = Rotating Location = INLETBC,INLETBC 2,INLETBC 3 BOUNDARY CONDITIONS: FLOW REGIME: Option = Subsonic END MASS AND MOMENTUM: Option = Cylindrical Velocity Components Velocity Axial Component = 281.8193 [in s^-1] Velocity Theta Component = 4.84281 [in s^-1] Velocity r Component = -36.78481208 [in s^-1] END TURBULENCE: Option = Medium Intensity and Eddy Viscosity Ratio END END END BOUNDARY: outer Boundary Type = OPENING Frame Type = Rotating Location = OUTERBC,OUTERBC 2,OUTERBC 3 BOUNDARY CONDITIONS: FLOW REGIME: Option = Subsonic END MASS AND MOMENTUM: Option = Cylindrical Velocity Components Velocity Axial Component = 281.8193 [in s^-1] Velocity Theta Component = 4.8428 [in s^-1] Velocity r Component = -36.7848 [in s^-1] END TURBULENCE: Option = Medium Intensity and Eddy Viscosity Ratio END END END BOUNDARY: outlet Boundary Type = OUTLET Frame Type = Rotating Location = OUTLETBC,OUTLETBC 2,OUTLETBC 3 BOUNDARY CONDITIONS: FLOW REGIME: Option = Subsonic END MASS AND MOMENTUM: Mass Flow Rate = 4541.632651 [lb s^-1] Option = Mass Flow Rate END END END DOMAIN MODELS: BUOYANCY MODEL: Option = Non Buoyant END DOMAIN MOTION: Angular Velocity = -31.52 [rev s^-1] Option = Rotating AXIS DEFINITION: Option = Coordinate Axis Rotation Axis = Coord 0.1 END END MESH DEFORMATION: Option = None END REFERENCE PRESSURE: Reference Pressure = 1 [atm] END END FLUID MODELS: COMBUSTION MODEL: Option = None END HEAT TRANSFER MODEL: Option = None END THERMAL RADIATION MODEL: Option = None END TURBULENCE MODEL: Option = SST END TURBULENT WALL FUNCTIONS: Option = Automatic END END END DOMAIN INTERFACE: Domain Interface 1 Boundary List1 = Domain Interface 1 Side 1 Boundary List2 = Domain Interface 1 Side 2 Interface Type = Fluid Fluid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END PITCH CHANGE: Option = None END END MESH CONNECTION: Option = Automatic END END OUTPUT CONTROL: MONITOR OBJECTS: MONITOR BALANCES: Option = Full END MONITOR FORCES: Option = Full END MONITOR PARTICLES: Option = Full END MONITOR POINT: Monitor Point 1 Cartesian Coordinates = 0.0[m],0.0[m],0.0[m] Option = Cartesian Coordinates Output Variables List = Pressure END MONITOR RESIDUALS: Option = Full END MONITOR TOTALS: Option = Full END END RESULTS: File Compression Level = Default Option = Standard END TRANSIENT RESULTS: Transient Results 1 File Compression Level = Default Include Mesh = No Option = Selected Variables Output Variables List = Pressure OUTPUT FREQUENCY: Option = Every Timestep END END END SOLVER CONTROL: ADVECTION SCHEME: Option = High Resolution END CONVERGENCE CONTROL: Maximum Number of Coefficient Loops = 30 Timescale Control = Coefficient Loops END CONVERGENCE CRITERIA: Residual Target = 1.E-4 Residual Type = RMS END TRANSIENT SCHEME: Option = Second Order Backward Euler TIMESTEP INITIALISATION: Option = Automatic END END END END COMMAND FILE: Version = 11.0 Results Version = 11.0 END EXECUTION CONTROL: INTERPOLATOR STEP CONTROL: Runtime Priority = Standard EXECUTABLE SELECTION: Double Precision = Off END MEMORY CONTROL: Memory Allocation Factor = 1.0 END END PARALLEL HOST LIBRARY: HOST DEFINITION: amhl Installation Root = /usr/ansys_inc/v%v/CFX Host Architecture String = intel_ia64_linux2.4 END END PARTITIONER STEP CONTROL: Multidomain Option = Independent Partitioning Runtime Priority = Standard EXECUTABLE SELECTION: Use Large Problem Partitioner = Off END MEMORY CONTROL: Memory Allocation Factor = 1.0 END PARTITIONING TYPE: MeTiS Type = k-way Option = MeTiS Partition Size Rule = Automatic Partition Weight Factors = 0.050, 0.050, 0.050, 0.050, 0.050, 0.050, \ 0.050, 0.050, 0.050, 0.050, 0.050, 0.050, 0.050, 0.050, 0.050, \ 0.050, 0.050, 0.050, 0.050, 0.050 END END RUN DEFINITION: Definition File = \ /Uns\ teady_J0751.def Initial Values File = \ /Unsteady_J0751_002.res Interpolate Initial Values = Off Run Mode = Full END SOLVER STEP CONTROL: Runtime Priority = Standard EXECUTABLE SELECTION: Double Precision = Off END MEMORY CONTROL: Memory Allocation Factor = 1.0 END PARALLEL ENVIRONMENT: Number of Processes = 20 Start Method = SGI MPI Local Parallel Parallel Host List = amhl*20 END END END .................................. .................................. ***usual calculations only for one iteration which are ignored here... ................................... then the following message appered: Execution terminating: maximum number of time-step iterations, or maximum time has been reached. Please let me know if you need further informations. |
Edmund Singer P.E.
Rep Power: 21 ![]() |
Pay attention to what Claudia said. I bet you modified the def file, but restarted the res file, which remained unmodified.
Use solver manager to modify the res file and restart that one. |
Ugly Kid Joe
Rep Power: 16 ![]() |
Make changes to your .cfx file > Save it > Press Define run > save > Overwrite (if .def file already exist with the same name) > Check the Initial value specification check box > Browse to .res file previously created > Start run.
Your simulation will start from 480 upto 720. |
#8 | |
sam13
@Singer: I never modified the res file. CFX manual is not clear enough at this point. Here is what the manual says- "To continue a previous run using the same specifications but for a further number of iterations, you can select a previously created Results File and use it as the Input File." But your idea makes sense to me. Let me have a try. @vmlxb6: Thanks for your suggestion. |
#9 |
Edmund Singer P.E.
Just use solver manager to edit. Tools>Edit CFX Solve File
and choose your .res file. When you submit the job to run, submit the .res file. It will pick up where it left off and continue with the updated changes. |
#10 |
sam13
It's so weird that it did not work for me. I am so frustrated now. It starts from where it left off but stops after only one iteration. I tried with several ways as follows:
1. Tools > Edit Current Results File [modified the .res file] Define run> Definition file : modified .res file 2. Tools > Edit Current Results File workspace>Restart current run 3. modified .def and used the .res file as the initial values file. And ironicaly none of them worked!! What should I do now? Is it a license issue or I'm missing something? |
#11 |
Edmund Singer P.E.
I am at a loss. Never had any issue with this before.
Does it take long to run? Just restart it from the beginning with the updated iteration number. Or, make a new def file, start time is end time of old run, update iterations, and use interpolator to interpolate the old res onto the new def file. |
Pros and Cons for CFX, CFdesign, COMSOL | Val | Main CFD Forum | 3 | June 10, 2011 03:20 |
how to continue iteration after stopping in CFX | nuimlabib | Main CFD Forum | 0 | July 6, 2010 12:44 |
CFX doesn't continue calculation... | mactech001 | CFX | 6 | November 15, 2009 22:25 |
2D CFD code using SIMPLE algorithm | bfan | Main CFD Forum | 3 | June 22, 2002 23:01 |
EULER-Forward-Method | freak | Main CFD Forum | 4 | June 12, 2001 10:19 |
