Free Surface Flow
Old   February 14, 2011, 02:23
Default Free Surface Flow
Vishal
vishal.indomitable is on a distinguished road
Send a message via Yahoo to vishal.indomitable
Hi Dear all,
I want to use ANSYS CFX to model a jet of water coming out of nozzle impinging on a flat plate. The inlet boundary condition is Velocity at the inlet of the nozzle. What can be the outlet boundary conditions and the expressions for creating the jet of water in air?
Please help me.
vishal.indomitable is offline   Reply With Quote
Old   February 14, 2011, 05:54
For setting up what I assume is a free surface multiphase simulation have a look at the flow over a bump tutorial example.
Your outlet can probably be an outlet or opening. Which is best will depend on exactly what you are modelling.
Old   February 15, 2011, 03:37
alastormoody11 is on a distinguished road
you can also take a look at Flow from a circular vent which deals with smoke jet emanating from a chimney and hence is very much similar to your simulation. Also regarding the boundary conditions you can choose a pressure outlet as the boundary by taking a sufficiently large CV.
alastormoody11 is offline   Reply With Quote
Old   February 22, 2011, 00:05
Vishal
Thank You Dear. Thanks for your reply. I've tried these tutorials. Outlet boundary condition will be opening to atmosphere i.e., constant pressure at outlet. But I've not got the results accurately. Some expressions or functions needs to be defined. Please Can you suggest me what expressions should I create?
Old   August 24, 2011, 07:44
Vishal
Hello Dear all,
Greetings of the day. Please someone help me in creating the expressions. I've tried many but the results using function calculator and theoretical results vary by about 9.72% which is vary large.
Thermocapillary free surface flow zakifoam OpenFOAM Running, Solving & CFD 10 December 12, 2016 12:44
free surface flow past cylinder vineet FLUENT 1 February 22, 2011 00:11
CFX gravity driven free surface flow tutorial mechovator CFX 37 July 27, 2009 11:28
free surface flow in non-inertial reference frame Tiedingg FLOW-3D 1 February 26, 2009 20:51
Free surface flow simulation question Jane Luo FLUENT 1 April 23, 2004 05:26
