February 10, 2011, 04:01 |
Axial Fan Mesh
Rep Power: 16 |
Dear All,
Please take a look at this mesh, which is a meridonial view of a fan blade passage. I was wondering does the inlet and outlet have to be vertical, i.e. normal to the flow direction in the axial-radial plane? This would obviously cause a large stretching of the elements near the top of the mesh and would negatively affect the mesh quality. However is this necessary for a correct representation? I am using total pressure at inlet and static pressure at outlet boundary conditions. Thank you |
February 10, 2011, 04:16 |
Rep Power: 144 |
No, the boundary does not need to be normal to the flow. Things are a little nicer if they are normal, but you can run it not normal.
February 10, 2011, 04:37 |
Rep Power: 16 |
Thank you for your reply Glenn!
I am trying to run the case with the corrected mesh as well to see how much it affects the efficiency. |
axial, boundary, fan, mesh |
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 00:27 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 12:21 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
axial flow in counter rotating ducted fan | Vishu | FLUENT | 4 | January 13, 2004 17:52 |
Published Axial Fan Data | Vincent Johnston | Main CFD Forum | 2 | July 14, 1999 00:49 |
