February 10, 2011, 03:47 |
Mesh stiffness in 1 way FSI
Ugly Kid Joe
Rep Power: 16 |
In default domain we define the mesh stiffness. Does the mesh stiffness interfere with the displacements ?????
Thank you. |
February 10, 2011, 05:14 |
Rep Power: 144 |
It is a weighting factor on the mesh smoothing algorithm. So I guess, yes, it does "interfere with the displacements".
February 10, 2011, 05:15 |
Ugly Kid Joe
Rep Power: 16 |
How should I determine the value of my Stiffness factor ???
February 15, 2011, 10:24 |
Rep Power: 21 |
The mesh stiffness doesn't change the motion of the boundaries (unless the boundaries are unspecified, then it can have an indirect effect), so different stiffnesses give the same flow solution. If your mesh quality remains OK then there's no need to change the stiffness. If the mesh folds or the quality becomes poor then a different stiffness may help. For example increasing the mesh stiffness near boundaries produces a stiff boundary layer mesh (i.e. it moves with the boundary rather than getting compressed).
February 15, 2011, 17:17 |
Ugly Kid Joe
Rep Power: 16 |
Thank you.
[ICEM] Negative volume error in hybrid mesh | siw | ANSYS Meshing & Geometry | 4 | September 3, 2014 06:25 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
Mesh Stiffness Option for Mesh Deformation | Ste_Lakey | CFX | 3 | January 19, 2006 17:33 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
