Ignition patch in coal combustion
Old   February 9, 2011, 09:29
Default Ignition patch in coal combustion
Bharath kumar
bharath is on a distinguished road
hi to all,
am doing a coal combustion simulation.In that is there a patch needed to ignite the volatiles in CFX13 (in EDM combustion model)? Now am using wall temperature as high to start the combustion.
thanks in advance
bharath is offline   Reply With Quote
Old   February 12, 2011, 07:20
joey2007 is on a distinguished road
Combustion modeling is not plug and play. You will never be sucessfull without a basic understanding of the modeled physics and chemistry and how it is formulated.
Guess in the template for coal combustion EDM is used. EDM works by source terms in the species transport equation and this term does not use temperature or energy. How shoud it feel your temperature increase?
This is done by fluent and other codes in similar way. It does not help to change the code. You have to work in to the details by reading some books and do an extensive training or course.
Good books are Warnatz (*), Maas and Dibble for beginners. For Phd students I would recommend Poinsot and Veynante.
In order to become combustion modeller who is able to work on his own you require a 2-3 month work in and 2-3 years work together with a combustion expierenced advisor.
Not to do so will end up in chaos and failed projects for 98% of the students and young cfd engineers.
Please do not forget: I am not paid for answering your questions.
Thousands of issues can cause a division by zero. Please do not capture a thread, with the argument: "I have the same issue ...."
joey2007 is offline   Reply With Quote
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 03:34
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
