February 8, 2011, 19:31 |
CFX Importing
Adrian Dunne
Rep Power: 15 |
I generated a 2D mesh (1 element thick), in ICEM CFD.
When I import it to ANSYS-CFX, I am unable to define any boundaries. When I det the solver to ANSYS-CFX in the solver tab within ICEM, I am unable to define any boundaries either. I would appreciate any help with this. |
February 8, 2011, 23:50 |
Rep Power: 16 |
FYI: Ideally, post this in the ANSYS CFX -> Meshing forum
you have to generate the boundary locations in ICEM CFD by making parts (if my memory is correct) with each one representing a boundary location. |
February 9, 2011, 03:27 |
Adrian Dunne
Rep Power: 15 |
I did this.
It won't allow me to create the boundary conditions from the parts in output when I select ANSYS-CFX as the solver. |
February 11, 2011, 06:35 |
Rep Power: 17 |
I am not ICEM user, but CFX-Pre allows you to create surface for boundary condition from physical boundary via edit mesh.
February 12, 2011, 00:31 |
Shahid Parvez
Rep Power: 17 |
No need defining BC in "Output". It is best to do an ICEM tutorial available in help.
Once you complete the mesh, add it to the part and then right click on "Part" in the "Model Tree" and select create part. Select each surface to create boundary locations. The associated mesh to the surface will automatically be assigned to that boundary location. After this you can "Output". |
February 12, 2011, 06:16 |
Joshua Counsil
Rep Power: 18 |
Make sure to be careful when defining parts, etc. in ICEM. If you're doing a 2D simulation in CFX, it's easiest to save your ICEM project as a Fluent V6 file and import it to Pre, which will automatically extrude it.
Here's a good tutorial on setting up parts for a 2D airfoil: http://www.youtube.com/watch?v=tYrbS...eature=related |
February 12, 2011, 08:31 |
Adrian Dunne
Rep Power: 15 |
Yeah, I actually have been using that tutorial as a guide all along ha. Thanks for that tip though. I'l try it out.
I managed to get it working though. I extruded the 2D mesh 1 element thick. In the extrude sidebar, I chose to name the extruded sides WALLS and extruded surface SYMMETRY. Then I hid everything except WALLS, chose create new part, then selected the blocks on the relevant wall face as my INLET, OUTLET etc. |
February 12, 2011, 11:12 |
Adrian Dunne
Rep Power: 15 |
I've another issue now, when I create the mesh, it has about 450,000 elements.
When I run the simulation in CFX-Solver, i see that it is using over 800,000 nodes. When I compare this with a mesh of similar size made in CFX-Mesh, the number of nodes roughly corresponds to the number of elements. I'm guessing that this is the reason that the ICEM model is using up twice as much RAM to compute. Can anybody shed some light on why this is happening? |
February 12, 2011, 16:47 |
#9 |
Joshua Counsil
Rep Power: 18 |
CFX effectively doubles the amount of nodes because it extrudes your 2D mesh to 3D (since it cannot perform 2D simulations).
February 14, 2011, 19:41 |
#10 |
Adrian Dunne
Rep Power: 15 |
I'm not quite doing it like that... When I extrude the mesh 1 element thick in CFX-Mesh, I get around 400,000 elements with 400,000 nodes.
When I create a 2D in ICEM, extrude it 1 element thick, I see in solver that it has 400,000 elements with 800,000. My issue is as to why this is happening, and how I can have it running on the same amount of nodes as CFX-Mesh. |
February 15, 2011, 07:26 |
#11 |
Rep Power: 144 |
How are you doing the counts?
The 400k elements and 400k nodes does not sound possible for a 1 element thick geometry. Should be 800k nodes. I suspect CFX-Mesh is just counting the 2D nodes and that is not correct. If you count them in CFX-Pre or CFD-Post (or in the mesh section of an output file) they will tell you the true node count. |
February 15, 2011, 10:13 |
#12 |
Adrian Dunne
Rep Power: 15 |
February 15, 2011, 17:46 |
#13 |
Rep Power: 144 |
I would need to look at your mesh to work out what is going on here.
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 20:42 |
Problem importing watertight model into CFX | djk1301 | ANSYS | 3 | February 1, 2011 23:04 |
Problems with importing ICEM-CFD mesh in CFX | signofra | CFX | 3 | March 3, 2010 11:08 |
Importing solutions in CFX. | Alphonso | CFX | 1 | August 1, 2008 15:01 |
importing mesh from ICEM CFD into CFX 5 | Jay | CFX | 2 | November 12, 2002 14:46 |
