Running UDFs in parallel
Old   February 1, 2011, 07:03
Default Running UDFs in parallel
Emre Turkoz
Emre Turkoz is on a distinguished road
I wanted to calculate PMV & PPD, namely some runtime additional variables with my analysis. To do that, I had to compile a Fortran file, usr_pmvppd.F, modify ccl and put it into CFX etc. I'm fine with all that. The only problem is that I can't run it in parallel. Serial solution works. Should we include an extra expression while compiling usr_pmvppd.F as in the case of double precision: cfx5mkext -double?
Thank you very much for your help.
Emre Turkoz is offline   Reply With Quote
Old   February 1, 2011, 09:51
Claudia is on a distinguished road
Try to set up an identical case without your UDFs, then make a partition file and set up your case including UDF with using this partition file.
Hope this will help.
Claudia
Claudia is offline   Reply With Quote
Old   February 1, 2011, 10:10
Emre Turkoz
Thank you, Claudia.
I found out where my mistake lies. I tried to use MPICH2 protocol but the ccl file of cfx5mkext is in the way that MPI parallelization should be used.
Best Regards,
Emre.
Running PimpleDyMFoam in parallel paul b OpenFOAM Running, Solving & CFD 8 April 20, 2011 06:21
problem using property udfs in parallel mode EllenW Fluent UDF and Scheme Programming 5 July 10, 2009 05:31
problem using property udfs in parallel mode EllenW FLUENT 0 June 23, 2009 18:18
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
