Calculating the force exerted on an object from fluid pressure
Old   January 30, 2011, 15:54
Default Calculating the force exerted on an object from fluid pressure
amrbekhit is on a distinguished road
Hello all,
I'm using ANSYS 13 Workbench/CFX in order to determine the fluid pressure exerted on an obstacle inside an active pipe and from that, determine the forces exerted on the obstacle. I've managed to perform the simulation and produce a contour map of the pressures exerted on the obstacle (shown in the attached image). Now what I'm trying to do is use that information to determine the overall force exerted on the robot by dividing the pressure on each face by its area and then summing up the forces. However, short of simply doing this by eye and reading the pressure values from the diagram, I'm not sure how to use the actual data computed in CFX to determine the average pressure on each face. How would I go about doing that?
Thanks
--Amr
amrbekhit is offline   Reply With Quote
Old   January 30, 2011, 17:38
Use the built in force functions. Much more accurate than calculating average pressures (and this approach does not include viscous forces anyway).
The CEL expressions like force, force_x, torque are what you are looking for.
average, cfx, fsi, obstacle, pressure
How to read pressure at discrete points paka OpenFOAM 16 April 28, 2020 08:26
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
DEFINE_CG_MOTION and pressure force Teo Fumagalli FLUENT 0 April 11, 2008 11:25
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
Too high pressure force ? Tim Franke Main CFD Forum 1 March 15, 2000 00:36
