Mesh deformation
Old   January 28, 2011, 15:40
Question Mesh deformation
morteza
kimiaghalam is on a distinguished road
I want to define a wall boundary condition which is moving and just the thing I know about its movement is the equation of motion which is y^2 + (a^2/h - h)y + x^2 + z^2 - a^2= 0 (a is a constant and h is changing with time), how can I do this ?
kimiaghalam is offline   Reply With Quote
Old   January 28, 2011, 16:09
If the motion is tangential to the wall you can do it by applying a tangential velocity to the wall boundary condition. If the motion has any component normal to the wall (it the fluid domain gets bigger, smaller or moves) you need moving mesh.
There are examples of both types that come with CFX tutorials.
Old   January 29, 2011, 18:40
Question
morteza
Thanks for your consideration sir.
The wall boundary moves in normal direction but the problem is that the velocity in y direction changes with x and z (as you can see in the equation) so I can not give an specific value for V. Could you please let me know how can I input a different velocity for each r (x^2 + y^2). I am kinda lost in those tutorials. I dont know if I have to write a code in fortran or I can write an expression directly on cfx. Help me
Old   January 30, 2011, 05:43
If you are lost in the tutorials then do them again until you understand. You will never get anywhere until you understand the basics.
You should be able to do what you propose in CEL expressions in moving mesh. No need for fortran.
ccl, cel, mesh deformation
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
CFX mesh deformation YY CFX 0 May 3, 2008 19:52
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
