ANSYS and CFX not talking in two-way FSI?
Old   January 27, 2011, 04:16
Default ANSYS and CFX not talking in two-way FSI?
Donald Brashear
brashear is on a distinguished road
I get the following error when I try to update my CFX-Pre:
In Analysis 'Flow Analysis 1' - Analysis Type: The specified Mechanical Input File 'ds.dat' can not be found or does not contain any valid interfaces. Specify an input file with valid interfaces, update the file location if it has moved or set the External Solver Coupling option to "ANSYS MultiField via Prep7".
I started the FSI analysis by starting an ANSYS transient analysis, which I confirmed to be solvable by itself. Then I deleted the results then to "Transfer Data to New -> Fluid Flow (CFX)" from the setup. I defined my fluid-structure interface loads in ANSYS.
I tried pointing manually to the 'ds.dat' file under dir\dp0\SYS\MECH\ds.dat, but the same error results.
Any thoughts? Thanks
brashear is offline   Reply With Quote
Old   January 31, 2011, 12:17
stumpy is on a distinguished road
In the Project Schematic delete the link between the ANSYS Setup cell and the CFX Setup cell, then re-create it and refresh CFX-Pre. That usually fixes this problem for me.
stumpy is offline   Reply With Quote
Old   May 5, 2012, 08:32
Ivailo Rusev
et1ap2 is on a distinguished road
I have the same problem as brashear. I tried to delete and re-create the link between setup cells of ANSYS and CFX, but the error still exists Do you have any other suggestions? Thanks in advance
et1ap2 is offline   Reply With Quote
Old   May 5, 2012, 11:49
sajad
sajad_abasi is on a distinguished road
hi
i had this problem too.but i saved it in this manner and closed workbench after that i open it again and it works right.
sometimes you should specify the file path yourself for the software
hope to help you
sajad_abasi is offline   Reply With Quote
Old   May 5, 2012, 23:17
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
As Stumpy said it should work (always does for me).
If not I think you should try, >Project Directory\dp0\CFX\CFX, and use the ./ds in CFX so you have no issues when changing the project directory path.
Gweher is offline   Reply With Quote
Old   June 13, 2012, 06:15
Wei Zhao
Alanseu is on a distinguished road
Actually it is the missing of FSIN_No# in defining the boundary of Interface of fluid and solid in CFX-re, which cause the ds.dat cannot been found or others.
Alanseu is offline   Reply With Quote
Old   November 25, 2012, 09:13
SteelMan is on a distinguished road
Send a message via Skype™ to SteelMan
I met the same problem. I copied the ds.dat into the target folder from an old project and it works. I checked the contents of the file(ds.dat )and it was updated according to new project.
SteelMan is offline   Reply With Quote
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! Cirion0000 CFX 0 July 6, 2009 15:26
FSI using Ansys LS-Dyna and CFX YY CFX 2 April 9, 2008 07:40
Ansys CFX 11 FSI and ICEM Sheeko CFX 3 November 16, 2006 07:42
MFX - for FSI between Ansys Multiphysics and CFX? Zerocles CFX 1 June 5, 2006 09:23
FSI using CFX and ANSYS Bi Chang CFX 2 May 10, 2005 05:47
